Definite Integration: Solving Homework Problem
  • Thread starter Thread starter Saitama
    Integration
The discussion revolves around a definite integral involving trigonometric functions, specifically the integral of \(3x^2 \sin\left(\frac{1}{x}\right) - x \cos\left(\frac{1}{x}\right)\) from 0 to \(4/\pi\). Participants are exploring methods to approach the integration of these functions, particularly focusing on the challenges posed by the sine and cosine terms.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss splitting the integral into separate parts and the implications of doing so. There are mentions of the cosine integral and the potential lack of elementary solutions. Some suggest using integration by parts, while others question the effectiveness of this method. The idea of treating the integrand as a derivative of a product is also introduced.
The discussion is active, with various approaches being proposed. Some participants have offered hints and insights that seem to guide others toward potential methods of tackling the integral. There is a mix of skepticism and optimism regarding the feasibility of finding a solution, with no explicit consensus reached on the best approach.
Participants note the complexity of the integral and the challenges associated with integrating functions that involve \( \sin\left(\frac{1}{x}\right) \) and \( \cos\left(\frac{1}{x}\right) \). There is also a mention of the use of tools like Wolfram Alpha for checking results, which may influence the discussion on the validity of certain approaches.
Saitama
Solve:
[tex]\int_{0}^{4/ \pi} 3x^2 \cdot sin(\frac{1}{x})-x \cdot cos(\frac{1}{x})dx[/tex]
I am stuck on this question because i really have no idea what should i be doing here with sin(1/x) and cos(1/x). I do not know how to integrate them. Even if i try to integrate by parts, i am stuck with these sin(1/x) and cos(1/x).
Any help is appreciated.
Thanks!
First, notice that you can split the integral into two different integrals. I will do one of them.
[tex]\int_{0}^{4/\pi}x\cos\left(\frac{1}{x}\right)\,dx=\int_{\pi/4}^{\infty}\frac{\cos(t)}{t^3}\,dt[/tex]
The expansion of this integral involves the cosine integral, the case with sine is not very different. This makes me think that the integral has no elementary expansion, but I'm not sure. There might be a way to do it without splitting the integral.
I have no idea what you meant by the "cosine integral".
If i rewrite the expression as you said:
[tex]\int_{\pi/4}^{\infty} \frac{3\sin(t)}{t^4}-\frac{\cos(t)}{t^3}\,dt[/tex]
What should i be doing next?
The indefinite integral has no representation via elementary functions. The definite integral has to be computed in some other way, e.g., via the residue theorem of complex analysis.
Well, if you plug in the indefinite integral in wolfram alpha, the answer it shows is x3sin(1/x).
I beg to differ ,
This question can be tackled , by using integration by parts ,
Let me give you a hint Pranav arora
If you integrate 3sin(t)/t^4 , using integration by parts.
Then one of two terms would be cos(t)/t^3 , which gets canceled . and you are left with a simple integral which can be solved very easily :)
Indeed. The addends cannot be integrated separately, but together the nicely cancel out the nasty part.
kushan said:
I beg to differ ,
Excellent, thanks kushan! That really worked! :smile:
Your welcome :cool:
Nice trick, Kushan!
Pranav, you should think of a trick if you are given such a problem.
Try to consider the integrand as the derivative of a product (fg)=f'g+fg'.
3x^2 is the derivative of x^3. cos() is the derivative of sin(), so find the derivative of sin(1/x)... It is -cos(1/x)/x^2. f'g+fg'=3x^2sin(1/x)-x^2cos(1/x)1/x^2= 3x^2sin(1/x)-xcos(1/x)
ehild
Man, your trick made the question lot easier than before, thank you very much ehild! I will always try to use this wherever possible. :smile:
As for the derivative of sin(1/x), it is -1/(x2)*cos(1/x).
So according to the trick, the answer is x3sin(1/x). If i differentiate this, i get the same equation as mentioned in the question.
Right. Suck tricks are very useful in school, but hardly ever applicable in real life... Life is ugly.:-p
ehild
ehild
Yes this is really helpful , and these kind of question are very common here , they look impossible though at first look .
  • · Replies 40 ·
  • · Replies 19 ·
