Questions on Mechanics (moments)
  • Thread starter Thread starter faisal
    Mechanics Moments
The discussion revolves around the concept of moments in mechanics, particularly in relation to Archimedes' famous statement about moving the Earth with a lever. Participants are exploring the principles of moments, equilibrium, and the practical implications of Archimedes' suggestion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to understand how to apply the principle of moments to Archimedes' statement and questions the practicality of such a scenario. Other participants discuss the limits of force generation and its relation to moment generation, while some seek clarification on definitions and calculations related to moments.
Participants are actively engaging with the concepts, with some providing definitions and explanations of moments. There is a mix of verification of calculations and exploration of theoretical implications, but no consensus has been reached on the practicality of Archimedes' claim.
Some participants question the physical constraints of force generation and the feasibility of the lever length required to move the Earth, indicating a need for further exploration of these assumptions.
faisal
in the context of the lever, archimedes is recorded as saying
''give me a long enogh lever and i will move the earth''
explain in terms of moments the point archimedes was making
how can i tackle this question?, i know the principle of moments the sum of the clockwise direction=the sum of the anti clockwise (in equalibrium) i don't know how i can apply it to this question.
the second part of the question states
Comment on how pratical Atchimedes suggestion really is?
The magnitude of the FORCE we are able to generate has definite limits, but does that set a limit on how large MOMENT we may generate?
Just to verify yourcalcuations,IIRC the length of lever to really move the Earth out of it's trajectory should be something round 10^{20}m (it may as well be Km) which would have one end under the Earth & the other out of our Galaxy... :-p
Daniel.
I thought Arch. said "Give me a place to stand on, and I will move the earth" :frown:
i don't understand, can you elaborate ?
What's the definition of the force's moment...??(In vector form,please)
Daniel.
A moment is the cross product of force and distance or the magnitude of the moment is Fd*sin(b) where b is the angle between the force and the moment arm (lever). Think of it this way:
If you want to push a door open you would push perpendicular to the door at the farthest point from the hinge giving you the maximum moment on the door. If you were to push the door at some angle other than 90 degrees to it you would have a smaller moment because only a component of the force would be acting on the moment arm.
Now think of it this way. You can only apply a certain amount of force because of certain physical constraints (such as your own strength) but you need to move a very heavy object. The answer is to multiply the force you can generate by some number to move the large object (i.e. a lever) . So as Archimede's was saying "Give me a big enough lever and I can move the Earth" it would be theoretically possible.
So what is a moment?
Its F x r (F is your force vector and r is your distance vector.)
The magnitude being Fd*sin(b) or if your force is exactly perpendicular to the moment arm simply Fd.
  • · Replies 105 ·
  • · Replies 27 ·
15K
