| Thread Closed |
Determine resolution of use by modelling it as single slit |
Share Thread | Thread Tools |
| Aug28-12, 07:33 AM | #1 |
Model the pupil of the eye using a single slit. If the eye is able to notice changes in intensity of 20% show that it can distinguish two objects seperated by an angle of 0.00015 radians if =500nm and diameter=4mm. 2. Relevant equations I=Iosin^2((π/λ)asinθ)/ ((π/λ)asinθ)^2 sin θ=λ/a 3. The attempt at a solution I attempted to find a (width) from the intensity equation but it doesn't seem to work, so Im unsure of how to start the calculation, the question is worth 4 marks, any help would be appreciated :) |
| Aug28-12, 06:51 PM | #2 |
Mentor
You wrote I(θ) for a slit illuminated by a single source. You need to account for the fact that there are two sources, separated by an angle of 0.00015 radians. |
| Aug29-12, 07:05 AM | #3 |
O ok so the equation would be
I=Iosin^2((π/λ)asinθ-∅)/ ((π/λ)asinθ-∅)^2 it gives a hint to consider the intensity halfway between the peaks of the two images so i did ((π/λ)asin(θ-∅)) = ∏/2 but where do i put the intensity change of 0.2% to get (θ-∅) = 0.00015? |
| Aug30-12, 08:03 PM | #4 |
Mentor
Determine resolution of use by modelling it as single slitBut we have two sources. Let's say one of them is an angle ∅ away from the central axis, and one of them is on the central axis. You need to consider the intensity due to each source, and combine them to get the intensity in the combined diffraction pattern. |
| Nov15-12, 05:53 AM | #5 |
Hello, I am fairly new here. I posted one new question but I forgot how to do that. Can anybody assist me by telling me how to post a new question?
| Nov15-12, 06:54 PM | #6 |
Mentor
See this thread:
http://www.physicsforums.com/showthr...=1#post3977513 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Determine resolution of use by modelling it as single slit
| Determine the slit-with and slit-distance of a double slit laser diffraction | Introductory Physics Homework | 1 | ||
| single particle single slit interference - question about the experiment | Quantum Physics | 6 | ||
| Rotating single slit and 2 single slits merging | Classical Physics | 17 | ||
| Doube slit electron with single slit photon emitter and detector | Quantum Physics | 0 | ||
| How to determine number of dark fringes by a single slit with only lamba and width | Introductory Physics Homework | 1 | ||
