How Does Electrostatic Force Affect Neutral and Charged Spheres?
The discussion revolves around the electrostatic interaction between a charged conducting sphere and a neutral conducting sphere. Participants explore the nature of the forces involved and the concept of polarization in this context.
  • Participants discuss the implications of Coulomb's law and the concept of charge induction. Questions arise regarding the nature of forces acting on the neutral sphere and the definition of polarization.
There is an active exploration of different interpretations regarding the forces between the spheres. Some participants suggest that polarization leads to attraction, while others question the net forces acting on the neutral sphere. Guidance on the definition of polarization has been offered, but no consensus has been reached.
Participants note the distinction between point charges and the behavior of conducting spheres, as well as the potential confusion surrounding the effects of induced charges on neutral objects.
leolaw
Sphere A carries a net charge and sphere B is neutral. Both are conducting spheres and they are placed near each other on an insulated table. Which statement best describes the electrostatic force between them?
a) there is no force b/w them since one is neutral
b) there is a force of attraction
c) there is a force of repulsion
d) the force is attractive if A is charged positively and repulsive if A is charged negatively.
I think answer (a) is right because according to Coulomb's law, [tex]F = k\frac{q_1q_2}{r^2}[/tex], and since that B is neutral so its net charge should be 0, which makes the entire equation equals to zero.
But then i was thinking about attraction by induction between sphere A and B. And if it does happen, then answer (b) is also correct.
Which one of my idea is right?
Coulombs law, only accounts for point charges. Conducting spheres with evenly distributed charge on their surface can act like point charges at their center, but once the charge becomes non-uniform, this is no longer so.
Yes it is true that there is not net charge on the neutral sphere, but it is polarized by the charged sphere, thus creating an attraction.
So what happen to the other end of the sphere B? If one end is attracted to sphere A, then the other should have an equal and opposite force toward the other end, which makes the net force becomes zero right?
By the way, what exactly does polarization mean?
They don't cancell out. Couloumb force is propotional to [tex]\frac{1}{r^2}[/tex].
So the repulsives force is much less than the attractive force here.
good question. The exact definition of polarization can be found in your book, but essentially it is the effects of a slight shifting of charge within the molecules of a neutral insulator due to some electric field. I'm not sure if this term extends to conductors (I'll have to go look it up).
To give an example, I borrowed an illustration provided by Gokul43201 (Thanks Gokul!) from a previous thread on similar topic, His illustration shows a similar thing for plates instead of spheres (since plates are easier to draw)
Gokul43201 said:
Consider the 2 parallel plates (easier to draw), one of which (the one on the right) has an excess charge, +Q.
The second plate will experience charge separation, whereby a negative charge is induced on the side nearer the other plate, and a positive charge on the far side. This makes sense : opposite charges attract, etc.
Code:
     II            I
  ________      ________
  |+ 0  -|      | +Q   |
since the negative charges are closer to plate 1 the attractive force is stronger then the repulsive force.
  • · Replies 29 ·
9K
