Calculating Velocity and Position with Constant Acceleration
  • Thread starter Thread starter Warcus
    Acceleration
The discussion revolves around calculating velocity and position for a vehicle under constant acceleration, specifically focusing on two tasks involving the vehicle's acceleration function and its implications for velocity and position over time.
  • Mixed
  • Participants explore the integration of acceleration to find velocity and position, with some questioning the initial setup and definitions of acceleration. There is also discussion about the relevance of kinematic equations in the context of non-uniform acceleration.
Some participants have provided guidance on integrating acceleration to find velocity and position, while others are working through calculations and expressing uncertainty about their results. Multiple interpretations of the problem setup are being explored.
There is mention of potential confusion regarding the notation used for acceleration and the implications of non-uniform acceleration on the choice of equations. Participants are also reflecting on their prior knowledge of calculus and integration.
Warcus
Hi there everyone! I'm a first-year physics student and I need some help with a couple of questions! OK, here it goes :)
Task 1​
The acceleration of a vehicle is given by a(t) = αT, where α=1.4 m/s^3. At the time t=1.0 s
the car has a speed of 5.0 m/s, what is the velocity at t=3.0 s?
(α = alpha) (In other words a(t)=α=1.4 m/s^3 is not a typo)
There are four possible answers:
(a) y (3) = 6.3 m / s
(b) v (3) = 7.4 m / s
(c) y (3) = 8.7 m / s
(d) y (3) = 11 m / s
Task 2​
We use with the same car as in the previous problem. We learn that the car
position at t = 1,0s is 5.0 m Find the car's position at t = 3.0 s
(a) x (3) = 15m
(b) x (3) = 18m
(c) x (3) = 20m
(d) x (3) = 23m
The relevant equations would be the kinematic equations for constant acceleration:
V = Vo + at
X = Xo + volt+ 0.5aT^2
V^2=Vo^2 + 2a(-Xo)
Task 1​
V = Vo + at
V = 5 m/s + 1,4 m/s^2 *2 s (the difference between the two t-values is 2)
V = 7,8 m/s
This answer is not one of the possible solutions --> I have done something wrong
Possible solutions (again):
Task 2​
X=volt + 0,5at^2
X=5 m/s x 2 s + 0,5*1,4 m/s^2 * (2s)^2 (Again, the difference between the t-values = 2)
X = 12,8 m
The task specifies that the distance at T(1)=5 --> Total distance = 5 m + 12,8 m = 17,8
Again, ther are four possible answers, and I'm fairly sure that the answer is b:
(a) x (3) = 15m
(b) x (3) = 18m
(c) x (3) = 20m
(d) x (3) = 23m
Nevertheless, I am a bit unsure about my calculation, and posted this Task as well :)
Thanks a lot for your help! :D
Warcus said:
Task 1​
Hi Warcus. Welcome to PF. :smile:
In the formula for the acceleration you meant t instead of T I think.
So a(t)=αt, and α=1.4 m/s3, so a(t)=1.4t.
This is the case of non-uniform acceleration, your relevant equations are irrelevant :-p.
Go back to the definition of acceleration: it is the time derivative of velocity. a=dv/dt. The opposite is also true: the velocity is obtained by integrating the acceleration: v(t)= ∫a(t)dt, and adding an arbitrary constant. The constant can be found from the condition that v=5.0 m/s at t=1.0 s.
ehild
Hi and thanks for the assistance ehild! I tried doing what you said, but as this is my first year studying physics I encountered some problems... Take a look, will you?
v(t) = ∫a(t)dt
v(t) = (t^a) * t + C (where a is 1,4t)
v(3) = (3^1,4*3) * 3 + C = 9,12 + C
Vo = V(1) = 1,4(1) + C --> C = 3,6
v(3) = 12,72
which can't be right according to the answers the teacher gave me.. :confused:
Could you try working it out step-by-step so I can see how it is done? :rolleyes:
The acceleration is a=1.4 t. v(t) is the integral or primitive function of the acceleration. V(t)=∫(1.4 t dt) = 1.4 ∫(t dt) =1.4 t2/2+C. You have studied some calculus , about integration, have you not?
Now substitute t=1 and v=5 and you get C.
Use that value of C to get the velocity at t=3 s.
ehild
V(t) = (1.4*t2)/2 + C
C = V(t) - (1.4*t2)/2
C = V(1) - (1.4*12)/2
C = 5 - (1,4 *12)/2
C = 4,3V(t) = (1.4*t2)/2 + C
V(3) = (1.4*32)/2 + 4,3
V(3) = 10,6
V(3) ≈ 11
V(3) = answer number d
And yeah, I studied some integration, but hey... It was three years ago and was probably just the basics. Anyways, thanks for the help, it was greatly appreciated! :biggrin:
Do not stop yet. Task 2 says that it is the same car as before, which has the velocity (you know it already) V(t) = (0.7*t2 + 4.3. You need the position as function of time. It is the integral (antiderivative) of the velocity.
[tex]x=\int{v(t)dt}=\int{(0.7t^2+4.3)dt}[/tex]
Refresh your knowledge about the integrals (antiderivatives) If it is too difficult, you can cheat a bit.
http://calculator.tutorvista.com/math/585/antiderivative-calculator.html#
When you know the expression for x(t), you can find the unknown C again from the condition x=5.0 m at t=1.0 s.
ehild
Alright, task 2:
x = ∫v(t)dt = ∫(0.7t2+4.3)dt = (0.7t3)/3 + 4.3t + C
x = (0.7t3)/3 + 4.3t
x(1) = (0.7*13)/3 + 4.3*1 + C
5 = (0.7*13)/3 + 4.3*1 + C
C = 5 - 4.53333... = 0.4666...
x = (0.7*33)/3 + 4.3*3 + C
x = (0.7*33)/3 + 4.3*3 + 0.46666...
x = 19.6333
x ≈20 → Answer C
Thanks for helping me get the answers and teaching me to antideriviative! :biggrin: :biggrin:
  • · Replies 38 ·
