Change of variables in a second order SDE
The discussion focuses on deriving analytical expressions for the drift and variance in a coupled set of stochastic differential equations (SDEs) involving variables φ and v. The user, Simon, successfully applies Itô's lemma to find that the variance σ²_v takes the form of a Lorentzian function under specific conditions. The derived expression for σ²_v is σ²_v = (π² A² R²) / (2 t_c [v_B² + (v - v_r)²]), where v_B = (α n R) / t_c, with α approximately equal to 4.92. Simon seeks further clarification on deriving the Lorentzian form of σ²_v, potential phase dependence, and conditions when the approximation may not hold.
  • Understanding of stochastic differential equations (SDEs)
  • Familiarity with Itô's lemma and its applications
  • Knowledge of variances and drift in stochastic processes
  • Basic concepts of coupled systems in dynamical systems theory
  • Research the derivation of Lorentzian functions in stochastic processes
  • Study the implications of phase dependence in stochastic variances
  • Explore numerical simulation techniques for SDEs
  • Investigate the behavior of stochastic systems when approximations are violated
Researchers and practitioners in applied mathematics, particularly those focusing on stochastic processes, dynamical systems, and numerical simulations of SDEs.
sith
Hello everyone! I am fairly new to SDE theory, so I'm sorry if my question may be a bit naive. I have the following coupled set of SDE:s
[itex]d\phi = \frac{v - v_r}{R}d t + \frac{\pi}{\sqrt{t_c}}d W[/itex]
[itex]d v = A\cos(n\phi - \phi_w)d t + a_v d t + \sigma_v d W[/itex].
[itex]W[/itex] denotes a Wiener process, and the parameters [itex]v_r[/itex], [itex]R[/itex], [itex]t_c[/itex], [itex]A[/itex] and [itex]\phi_w[/itex] are constants. The functions [itex]a_v[/itex] and [itex]\sigma_v[/itex] are the drift and variance in [itex]v[/itex], respectively, solely due to the stochasticity in [itex]\phi[/itex]. So my question is: how do I derive analytical expressions for [itex]a_v[/itex] and [itex]\sigma_v[/itex]? I don't know if this helps, but when disregarding the stochastic processes in [itex]\phi[/itex] and [itex]v[/itex] it will turn into a second order ODE, and one will have the following constant of motion
[itex]H(\phi,v) = \frac{v^2 - 2 v_r v}{2 R} - \frac{A}{n}\sin(n\phi - \phi_w)[/itex].
My first thought of how to solve the problem was to rewrite the expression as [itex]v(\phi, H)[/itex] and using Itô's lemma
[itex]d v = \frac{\partial v}{\partial\phi}d\phi + \frac{\partial v}{\partial H}d H + \frac{1}{2}\left(\frac{\partial^2 v}{\partial\phi^2}d[\phi,\phi] + \frac{\partial^2 v}{\partial\phi\partial H}d[\phi,H] + \frac{\partial^2 v}{\partial H^2}d[H,H]\right)[/itex]
where [itex]d[X,Y][/itex] is the quadratic co-/variance. Is this a correct approach? Then how do I calculate the differentials [itex]d H[/itex], [itex]d[\phi,H][/itex] and [itex]d[H,H][/itex] for this particular case? Numerical simulations have indicated that [itex]\sigma_v[/itex] is on the form of a Lorentzian function in [itex]v[/itex], centered around [itex]v_r[/itex].
Thanks in advance. /Simon
I have made some progress in the work. Treating [itex]H[/itex] as constant [itex]\sigma_v[/itex] can be found to be
[itex]\sigma_v = \frac{\pi A R}{\sqrt{t_c}(v - v_r)}\cos(n\phi - \phi_w)[/itex]
by using Itô's lemma on the more simple form
[itex]d v = \frac{d v}{d\phi}d\phi + \frac{1}{2}\frac{d^2 v}{d\phi^2}d[\phi,\phi][/itex].
I also made a mistake in the previous post. It is not [itex]\sigma_v[/itex] that takes the form of a Lorentzian, but [itex]\sigma^2_v[/itex]. Specifically I have found that the Lorentzian approximation is valid in the limit [itex]A \ll \frac{n^3 R}{t_c^2}[/itex], and it then takes the form
[itex]\sigma_v^2 = \frac{\pi^2 A^2 R^2}{2 t_c[v_B^2 + (v - v_r)^2]}[/itex]
[itex]v_B = \frac{\alpha n R}{t_c}[/itex],
where [itex]\alpha \approx 4.92[/itex] is a numerical constant. This expression is consistent with the one derived when assuming [itex]H[/itex] is constant in the limit [itex]|v - v_r| \gg v_B[/itex], and averaging the expression over phase [itex]\phi[/itex]. The questions I am still left with are:
* How do I derive the Lorentzian form of [itex]\sigma_v^2[/itex], if it is even valid?
* Is there a phase dependence in [itex]\sigma_v[/itex]? (There are no indications on a phase dependence from numerical simulations)
* Is there a way to derive [itex]\sigma_v[/itex] when the condition [itex]A \ll \frac{n^3 R}{t_c^2}[/itex] is violated?
Of course I am also interested in estimating the drifts due to stochasticity in [itex]\phi[/itex], which I haven't even begun to look at in numerical simulations.
