Adaptive Cruise Control: Maintaining a Safe Following Distance
  • Thread starter Thread starter Dav15
    Control
This question pertains to adaptive cruise control systems in vehicles, focusing on maintaining a safe following distance based on speed and distance measurements. The discussion revolves around the dynamics of acceleration and deceleration necessary to sustain this distance, particularly in the context of a three-second rule for following distance on highways.
  • Participants explore how to determine the speed of a following car based on the known distance to the car in front, particularly considering the three-second rule. There are discussions about relevant equations and whether acceleration should be factored into the problem setup.
The conversation is ongoing, with participants providing insights and clarifications. Some guidance has been offered regarding the setup of the problem and the equations that may be relevant, but there is no explicit consensus on the approach or solution yet.
There is an indication that the original poster may be struggling with the formulation of the problem and the application of equations. The discussion also hints at the need for clarity regarding the role of acceleration in the context of maintaining a safe following distance.
Dav15
This question is related to adaptive cruise control in new vehicles.
Adaptive cruise control automatically determines the speed at which a vehicle should be traveling by measuring the distance between it, and the car in front (mainly for use on highways)
There is a general rule that three seconds is a safe following distance.
So I suppose that the question is trying to find the acceleration (or deceleration) that the vehicle needs to maintain that gap.
Of course this would cut out when the car reaches a speed, pre determined by the driver (to avoid speeding).Relevant equations
[tex]v=u + at[/tex]
The attempt at a solution
I honestly have no clue, I'm not going to bother with posting my attempt because it is so pitiful xD
Welcome to PF. No attempt is worthless because it let's people see where you are going wrong so they can help guide you to an answer. Also a lot of people won't help if you don't at least show some effort.
I'm not sure what exactly your question is either.
Thanks Bhumble,
My question is, if the distance between the two cars is known, how would I find the speed the following car should be going to maintain a specific distance (that distance is m/s x 3)
I drew a very rough diagram, to try explain what I am asking :)
EDIT: I apologise for my handwriting :)
It seems to me that you are interested in the position and with a given distance equivalent to 3 seconds of time.
Are you suppose to be considering acceleration as well?
[itex]s = s_0 + \vec{v} t + \frac{1}{2} a t^2[/itex]
Or are we just interested in position and velocity?
Either way the key to setting up the problem is to equate the positions of the two cars when the car in front is at time = t and the following car is time = t+3.
So
[itex]s_a(t=t) = s_b(t=t+3)[/itex]
Then it's just some algebra to solve for what you are interested in.
The equation that you put as relevant makes me think you are trying to ask a different question than you illustrated though.
  • · Replies 16 ·
13K
  • · Replies 22 ·
