Relating Movement of Electrons in Currents to Wire Movement/Energy/Power
The discussion revolves around the relationship between the movement of electrons in electrical currents and the physical movement of wires, particularly in the context of energy and power transmission. Participants explore theoretical implications, including the effects of electron drift velocity and kinetic energy in conductive materials.
  • Some participants propose that a very light wire carrying high currents could exhibit visible movement due to the acceleration of electron flow, referencing Newton's second law (F=MA).
  • Others argue that the kinetic energy of electrons is an insignificant fraction of the power delivered to a wire, suggesting that the energy transmitted is not primarily due to electron motion.
  • A question is raised about the form in which the bulk of energy is transmitted in an electric current, with suggestions that it may involve vibrations or other mechanisms beyond kinetic energy.
  • It is noted that electrical energy is fundamentally linked to voltage and charge movement, with references to relevant equations.
  • Some participants assert that electrical energy can only be extracted from a system through the movement of electrons or changes in an electric field, emphasizing the necessity of a dynamic system for energy flow.
  • There is a clarification that while kinetic energy of electrons may be negligible, the movement of charge is crucial for energy transmission, regardless of the mass differences between charge carriers like electrons and protons.
Participants express differing views on the significance of electron kinetic energy in energy transmission, with some asserting its insignificance while others emphasize the importance of charge movement. The discussion remains unresolved regarding the exact mechanisms of energy transmission in electrical systems.
Participants reference various physical principles and equations, but there are unresolved assumptions regarding the definitions of energy transmission and the role of kinetic energy in this context.
Islam Hassan
Off the Wikipedia:
"...in a copper wire of cross-section 0.5 mm2, carrying a current of 5 A, the drift velocity of the electrons is on the order of a millimetre per second."
Suppose we have a setup with a very very light wire which can transmit very very high currents. Once the current is switched on, can we detect a visible movement in the wire due to the initial acceleration of the electron flow (due to F=MA) within it?
Another question is taking into account electron density in a conducting copper wire, can we relate the electron speed to the energy/power provided by the wire taking into account E= 0.5mv^2?
IH
I would have to work it out to be sure, but my guess would be yes.
No. I have worked this out before, the KE of the electrons is an insignificant fraction of the power delivered to a wire.
Then in what form is the (bulk of the) energy/power of electrons transmitted in an electric current? Vibration/wiggling of electrons or something else?
IH
Electrical energy is electrical and magnetic. It depends on voltage and charge movement. You can see that in the equations.
Also, judging by the mass difference between an electron and a proton/neutron pair, I'd say the kinetic energy/force would be negligible.
Ok, understood.
Can we however say that electrical energy can only be extracted from a system via movement of electrons or changes in an electric field? That a static electical system may well contain electrical energy but that this can only 'flow' in a dynamic system?
Kinetic energy of electrons may be too weak to matter much, but I think that a dynamic system is essential to transmission of electrical energy.
IH
Yes. The movement of charges is called a current and is represented by the symbol j. In Poynting's theorem, the energy transferred to matter from the EM fields is given by E.j, so as you say, energy can only be extracted via movement of charges in the presence of an electric field.
Islam Hassan said:
Ok, understood.
IH
Sure, but note again that it is the charge that matters. Ie, a moving proton and a moving electron carry the same charge even though the proton is 1800 times more massive.
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 16 ·
