| New Reply |
Dot Product/Cross Product Interpretation, Geometric Construction |
Share Thread | Thread Tools |
| Sep4-12, 11:16 PM | #1 |
Given the nonzero vector a ε ℝ3, a[itex]\dot{}[/itex]x = b ε ℝ, and a × x = c ε ℝ3, can you determine the vector x ε ℝ3? If so, give a geometric construction for x. 2. Relevant equations a[itex]\dot{}[/itex]x = ||a||||x||cos[itex]\Theta[/itex] 3. The attempt at a solution I'm not really certain what it is asking for? Obviously, the cross product of the two vectors creates a vector perpendicular to all vectors in the a, x plane. And, the magnitude of the cross product defines the area of a parallelogram spanned by a and x. Also, ||x||cos[itex]\Theta[/itex] is the length of the projection of x onto a, which is also equal to b/||a|| But while I know all this, I don't know what I'm trying to show or how to show it? Any help would be great! Thanks! |
| Sep4-12, 11:36 PM | #2 |
Let's say you know the vector [itex]a[/itex] and all of its components. You know its dot product and cross product with [itex]x[/itex]. Can you use this information to actually figure out what each of the components of [itex]x[/itex] should be? Can you describe a picture in which it's clear how to figure out what [itex]x[/itex] should be?
| Sep4-12, 11:48 PM | #3 |
I know a lot of tedious algebra might describe it, but I guess I don't really know how I would describe a picture per se. I don't know how I would break it down to each of its components. |
| Sep4-12, 11:54 PM | #4 |
Right, it's not something that's immediately obvious in an an abstract sense, so let me rephrase the question.
If you have a point on the unit circle and you know both the sine of the angle it makes with the +x axis and the cosine as well, do you know the point's location on the unit circle absolutely? Do you have a formula for the cross product that involves either sine or cosine? |
| Sep5-12, 12:03 AM | #5 |
Yes, it would stand to reason that you would know that point.
And no, we have yet to learn such a formula. |
| Sep5-12, 12:12 AM | #6 |
Hm, without knowing that [itex]|a \times x| = |a| |x| \sin \theta[/itex] where [itex]\theta[/itex] is the angle between the vectors, I think it would be difficult to make the required connection.
Let's imagine for a moment that [itex]a,x[/itex] lie in some plane. It stands to reason that [itex]c[/itex] as defined in the problem is perpendicular to this plane. Obviously you don't know [itex]x[/itex], but you should be able to find some other vector in the plane just with [itex]a[/itex] and [itex]c[/itex]. In particular, if you use a cross product to do this, you'll know that the result will be perpendicular to [itex]a[/itex] yet still in the plane [itex]a,x[/itex] span. Once you're at this point, where you have two perpendicular vectors and [itex]x[/itex] must lie in the plane that they define, you should see that this is just a unit circle problem in some arbitrary plane. The dot product gives you the cosine, and the cross product gives you the sine. |
| Sep5-12, 12:27 AM | #7 |
Well, that formula appears nowhere in my notes, memory, or book up to this point. So I would assume he wants us to be able to solve the problem without it. Would that be possible?
Otherwise, crossing a with c would give me a vector y that lies in the a, x span. But then how are you applying the two formulas to determine the components of x? Are you using a and y? |
| Sep5-12, 06:02 AM | #8 |
That formula is one you should recognize as the area of the parallelogram formed by a and x.
It might help you to visualize the problem if you orient your coordinate system so that a points along the x-axis and x lies in the xy-plane. |
| Sep5-12, 07:20 AM | #9 |
Right, I can see the formula as being true. My fear was that as he had yet to introduce it in class, my professor may frown upon its use.
That said, I'm a bit confused about this idea of creating another vector in that same plane and using it to solve for x. I don't see how the formulas allow for that. |
| Sep5-12, 12:34 PM | #10 |
I wouldn't worry about using the formula. In fact, he might consider it something you should be able to deduce using basic trig and geometry from the fact that the magnitude of c is the area of the parallelogram.
| New Reply |
| Thread Tools | |
Similar Threads for: Dot Product/Cross Product Interpretation, Geometric Construction
| Deriving cross product and dot product, stuck at beginning. | Calculus & Beyond Homework | 8 | ||
| Angle between 2 vectors using 1) Dot product and 2) cross product gives diff. answer? | Calculus & Beyond Homework | 8 | ||
| cross product and dot product of forces expressed as complex numbers | Introductory Physics Homework | 4 | ||
| geometric algebra cross product | Linear & Abstract Algebra | 4 | ||
| geometric algebra cross product | Introductory Physics Homework | 0 | ||
