Affect of elevation on bicycle suspension
  • Context: Undergrad
  • Thread starter Thread starter ruadhrigh
    Bicycle Suspension
The discussion centers on the impact of elevation on bicycle suspension performance, particularly focusing on pneumatic and spring suspensions. Participants noted that while temperature significantly affects suspension behavior, the consensus on elevation's impact was less clear. Pneumatic suspensions, being air-tight, experience pressure differences that change with elevation, potentially affecting their performance. In contrast, spring suspensions are not influenced by external air pressure due to their design, leading to a divergence in opinions among riders regarding the effects of elevation.
  • Understanding of pneumatic suspension systems
  • Knowledge of spring suspension mechanics
  • Familiarity with the principles of air pressure
  • Basic concepts of temperature effects on materials
  • Research the design and function of pneumatic bicycle suspensions
  • Explore the effects of temperature on suspension performance
  • Investigate how elevation changes impact air pressure in sealed systems
  • Learn about pressure regulation mechanisms in advanced suspension systems
Bicycle enthusiasts, suspension engineers, and mountain bikers interested in optimizing their bike performance at varying elevations.
ruadhrigh
Last night I had a trailside discussion about how (or if) elevation differences could affect the performance of a bicycle shock. The idea was that air shocks should not be affected because the air spring is in a sealed vessel. Though one rider claimed his suspension acted differently at higher elevations.
We all agreed that temperature had a great affect on suspension, but disagreed on elevation.
What could be some of the ways that elevation would cause suspension to behave differently?
Elevation SHOULD have effects on a pneumatic suspension. First consider a spring suspension. It is not air tight, so the air pressure inside equals the air pressure outside, there is no pressure difference, so it is not affected by air pressure (short of smaller effect of air pressure on lubricants, but let's ignore those).
A pneumatic suspension, however, is air tight. So the pressure inside is independent of the pressure outside, and there is a pressure difference. That difference changes with elevation (unless there is a contraption to modify the internal pressure in accordance with the external pressure, which I don't think a bicycle suspension would have).
  • · Replies 0 ·
  • · Replies 42 ·
