How Can You Energize a 5V Switch Using a Microphone with 250mV Output?
  • Thread starter Thread starter hogrampage
    Electronic Switch
The discussion centers on designing a circuit to energize a 5V electronic switch using a microphone that outputs a peak voltage of 250mV. Participants agree that an instrumentation amplifier is necessary to amplify the microphone's signal to meet the 5V requirement. Additionally, a detection mechanism is needed to trigger the switch when the amplified signal exceeds a certain threshold, with a hold time to maintain the switch's state during and shortly after speaking.
  • Understanding of instrumentation amplifiers
  • Knowledge of signal amplification techniques
  • Familiarity with electronic switch operation
  • Basic concepts of voltage thresholds and detection circuits
  • Research how to design an instrumentation amplifier circuit
  • Learn about voltage threshold detection methods
  • Explore relay driving circuits for electronic switches
  • Investigate hold time mechanisms in electronic circuits
Electronics enthusiasts, circuit designers, and students working on projects involving audio signal processing and electronic switching mechanisms.
hogrampage
You're given an electronic switch which requires 5V at 1mA in order to close; it is open with no voltage present at its input. If the only microphone available produces a peak voltage of 250mV, design a circuit which will energize the switch when someone speaks into the microphone.
I really don't know how to start. Would I use an instrumentation amplifier or something else? If so, how would it be wired? Where would the signal from the microphone go?
Thanks
Thanks
You do need to amplify the signal, then detect when it is above some threshold, and have that detection trigger the drive to the relay and hold that drive steady for some time period (like for the duration of the speaking plus a couple of seconds maybe). The amplification does not need to be high fidelity -- you are just looking for when the signal from the microphone is above some detection threshold...
  • · Replies 17 ·
