Deal with tension problems in a systematic way?
  • Thread starter Thread starter StephenPrivitera
    Systematic Tension
The discussion revolves around tension problems in physics, specifically focusing on a freight train scenario and a block-and-ramp scenario. Participants explore the calculations of tension in various parts of the train and the relationships between forces acting on the blocks on a ramp.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to analyze the tension in a freight train's couplings by considering the forces acting on the cars and the locomotive. They also seek a systematic approach to tackle tension problems. Other participants question the assumptions regarding the mass of the train and suggest calculating the tension between specific cars. Additionally, a new scenario involving blocks on a ramp introduces questions about the relationship between their accelerations and the forces acting on them.
Participants are actively engaging with the original poster's calculations and reasoning. Some have provided clarifications and additional questions, while others are exploring different scenarios involving tension. There is a productive exchange of ideas, but no consensus has been reached on the final outcomes of the problems presented.
Participants are discussing tension problems under the assumption that the locomotive's mass is not included in the freight train's total mass. In the block-and-ramp scenario, there is a focus on the coefficients of friction and the need to clarify assumptions about the relationship between the accelerations of the two blocks.
StephenPrivitera
Something about tensions throws me off. I can never seem to get tension problems.
A freight train consists of 250 cars each of mass 64 metric tons. The acceleration of the train is a=0.043m/s2. What is the tension in the coupling that holds the first car to the locomotive? the last car? Ignore friction.
Here's a little diagram.
[___]---[___]---[___]---[___]---[___]\ ----->a
Let me treat the last car first. The free body diagram looks like this:
O-------> T
T=ma=2.75x10^3 N
Correct?
On the first car we have (ignoring normal force and weight, which cancel out),
<-----O----->
Right? Since the car pulls on the car behind it, the car behind it pulls on it. And the locomotive pulls on the first car is the forward direction.
If you treat the train as a whole, the net force is 6.88x10^5 N in the direction of a.
Considering the front boxcar,
T1 - T2=Fnet=ma
a is known, m is known, Fnet is known
T2 must be sufficiently large to accerelate the remainder of the train of mass M by a. So
T1=a(m+M)
T1=6.88x10^5 N since m+M is the total mass of the train
Is my work ok? Can you give me some advice on how to deal with tension problems in a systematic way?
Thanks.
You say "A freight train consists of 250 cars each of mass 64 metric tons." Can we assume that does NOT include the locomotive?
Assuming that, the cars behind the locomotive have a mass of
250(64)= 16000 metric tons= 1.6 x 106kg. Since "F= ma", in order to accelerate them at a=0.043m/s2, we must have
F= 1.6 x106* 4.3 x 10-2= 6.88 x 104 Newtons. The only way to do that is for the locomotive to pull them so that is the tension in the first coupling.
Now, can you calculate the tension in the coupling between the first and second cars?
And if you can do that, can you calculate the tension on the coupling between the first and second cars?
How about between the last and next to last cars?
Yes. It does not include the locomotive.
Sure.
I prefer general cases.
So I consider the nth car on a train of N cars. I want to find the tension in the cable connecting the nth car with the (n-1)th car.
Force diagram:
<------[__n__]---------> T2
T1
The mass of the car is m.
a is the acceleration of the car. It is also the acceleration of the train.
Fnet on n=ma=T2-T1
-T1 provides the acceleration of the N-n cars of mass m(N-n) behind n.
So T1=ma(N-n)
So T2=ma(N-n+1).
This result gives me the same answers I obtained before when I use N=250, n={250,1}.
That one was ok.
How about this one?
Two blocks slide down a ramp making an angle P with the horizontal. They are tied together by a string. They have coefficients of friction uk1 and uk2. What is a? What is T?
|.\[m2]
|...\[m1]
Nice diagram, huh?
Now on m1 we have,
<----- force of frition uk1(m1)gcosP
<----- force of tension T
-----> force of gravity (m1)gsinP
On m2 we have,
<----- force of frition uk2(m2)gcosP
-----> force of tension T
-----> force of gravity (m2)gsinP
(m2)(a2)= -uk2(m2)gcosP + T + (m2)gsinP
(m1)(a1)= -uk1(m1)gcosP - T + (m1)gsinP
I can conclude that T is the same for both equations since there is only one rope. Can I conclude that a1=a2? If so, how do I show that a1=a2? I often get in trouble with my problems because I assume things rather than showing them.
  • · Replies 38 ·
