Want to delay power in a series, how can I do that?
The discussion focuses on implementing an analog delay line circuit to sequentially power sections of a wire with a specific time delay (Δt) between each section. The user seeks a solution that can be soldered inline to achieve this effect. The suggested approach involves utilizing analog delay line circuits, which are well-documented in various datasheets available online. This method allows for precise control over the timing of power delivery to each wire segment.
  • Understanding of analog electronics and circuit design
  • Familiarity with delay line circuits and their applications
  • Basic soldering skills for electronic components
  • Knowledge of power delivery systems in electronic circuits
  • Research analog delay line circuit designs and schematics
  • Explore specific components used in analog delay lines
  • Learn about the practical applications of delay lines in electronic systems
  • Investigate soldering techniques for integrating components into existing circuits
Electronics hobbyists, circuit designers, and engineers looking to implement timed power delivery systems in their projects.
cowmoo32
I have a driver that sends power to a wire when it hears a sound. What I would like to do is cut the wire into sections and put something inline that would delay the power getting sent by a fraction of a second. So, wire 1 is powered, Δt, wire 2 is powered, Δt, wire 3 is powered, etc. Is there an analog way to do this? Ideally it would be something I could solder in between each section.
It sounds like you want to use an analog delay line circuit:
http://www.datasheetarchive.com/analog delay line schematic-datasheet.html
There are some datasheets for such parts/circuits.
10K
