Inner product of polynomials
The discussion focuses on the inner product of polynomials, emphasizing its role in determining the angle and distance between polynomial vectors. It establishes that the inner product serves as a projection, where the coefficients indicate the relationship between two vectors. A positive inner product signifies a directional component, while a negative value indicates opposition. The analysis involves decomposing a polynomial vector using orthonormal basis vectors, allowing for reconstruction through linear combinations weighted by the inner products.
  • Understanding of inner product spaces
  • Familiarity with orthonormal basis vectors
  • Knowledge of polynomial functions and their properties
  • Basic concepts of vector projection in geometry
  • Study the properties of inner product spaces in detail
  • Learn about orthonormal basis vectors in polynomial spaces
  • Explore polynomial decomposition techniques using inner products
  • Investigate applications of inner products in functional analysis
Mathematicians, computer scientists, and students studying linear algebra or functional analysis, particularly those interested in polynomial functions and their geometric interpretations.
matqkks
In inner product spaces of polynomials, what is the point of finding the angle and distance between two polynomials? How does the distance and angle relate back to the polynomial?
Hey matqkks.
It's easier to think of the inner product in an abstract space as a projection and the "weighting" or coeffecient that an object has with respect to the thing you are projecting on.
The concept of an angle is to help you make the leap from the geometric idea of relating one vector to another (through the inner product) with the "angle" between them to going to a generalized way of having a coeffecient that simply relates two vectors together with respect to its orientation.
If you recall your 3D geometry, you know that the inner product of two vectors is zero when they are independent, positive when they are relatively in the same direction and negative when they are not.
If you have a positive value it means the projection has a positive directional component with respect to the other vector and if negative it means the opposite. A zero value means that the basis vector contributes absolutely nothing to the other vector and vice-versa.
It's the idea of contribution between the two vectors and the relation of that contribution (the sign and the weighting) that is important.
So now to answer your question.
What you are basically doing in this analysis is you are taking some vector, your decomposing it by finding its projections with respect to a set of orthonormal basis vectors (which are polynomials themselves) and then just like the geometric examples, you re-construct the polynomial using a linear combination of the basis vectors (which in this case are polynomials not direction vectors in some geometric R^n space) by weighting each vector by the coeffecient given by taking the inner product of the polynomial with each individual basis vector.
So keep in mind that this idea of angle is just meant to be used as a way to numerically relate any two arbitrary vectors together and when you are able to relate one vector with all basis vectors that form a basis, then you are able to relate a vector to the entire basis (i.e. the entire space).
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 0 ·
