Calculating force of hydraulic cylinder
The discussion focuses on calculating the force generated by a hydraulic cylinder due to the expansion of heated air at 800 degrees Celsius. The user provides calculations involving a flywheel with a radius of 0.030m, rotating at 850 RPM, resulting in a moment of inertia of 0.0001215 kgm² and a kinetic energy of 0.48N. The user attempts to relate the force acting on a piston with a diameter of 0.020m to the pressure generated, ultimately questioning the accuracy of their calculations and the connection between the piston and the flywheel. Key errors identified include incorrect unit usage and dimensional inconsistencies between force and energy.
  • Understanding of thermodynamics principles, particularly gas laws
  • Familiarity with rotational dynamics, including moment of inertia and kinetic energy calculations
  • Knowledge of pressure-area relationships in hydraulic systems
  • Basic understanding of unit conversions in physics, specifically MKS units
  • Study the ideal gas law and its application in thermodynamic systems
  • Learn about the relationship between pressure, volume, and temperature in gases
  • Explore the principles of hydraulic systems and how force is transmitted through fluids
  • Investigate the mechanics of Stirling engines and their operational principles
Engineers, physicists, and students interested in thermodynamics, fluid mechanics, and mechanical systems, particularly those working with hydraulic cylinders and energy transfer systems.
CognitiveNet
I want to calculate the force generated (as a result of expanding air) from pressure created by heating air up to a maximum temperature of 800 degrees Celsius.
My flywheel with a radius of 0,030m is rotating at a speed of 850RPM and weights 0,27Kg.
Angular velocity: w=850RPM*(2pi/60)=89rad/s
Moment of inertia of the flywheel: I=0,5*m*r^2=0,5*0,27*0,030^2=0,0001215 kgm^2
Kinetic energy: Ek=0,5*I*w^2=0,5*0,0001215*89^2=0,48N
Now I use Thermodynamics to calculate the supplied heat.
The room temperature is 20 degrees Celsius and the piston is 0,020m in diameter.
Area of piston: pi/4 *d^2=pi/4 *0,020^2=pi*10^-4
Force acting on piston due to the pressure inside the cylinder: F=P*A
I'm assuming this force is equal to the kinetic energy stored in the flywheel.
Thus P=F/A=0,47N/pi*10^-4=1527Pa
P1*V1/T1=P2*V2/T2
(Excluding the volumes because I just care about the initial kinetic force)
Pa = Normal atmospheric pressure at 20 degrees Celsius (or 293 Kelvin)
Thus T2=P2*T1/P1=1527Pa*293K/101300Pa=4K IMPOSSIBURU!
But the supplied heat is at least 800 degrees Celsius.
Assuming all of the heat is transferred into the air inside the cylinder, that's equal to 1073K.
Please tell me what's going on here. I have the feeling that I don't know how to calculate how much force the air is acting on the piston, as a result of an increase of pressure due to the increase of temperature.
Science news on Phys.org
Your units are not correct. Energy has the dimension of Force x distance and units in MKS are Joules.
This is also dimensionally incorrect. Force cannot equal energy.
You have not explained the problem very well. Perhaps if you explained exactly how the piston is connected to the flywheel, we might be able to help you out.
AM
AM
It's a Lamina Flow Stirling, or a thermodynamic stirling.
  • · Replies 45 ·
  • · Replies 23 ·
11K
