Partial Derivates - Chain Rule
The discussion focuses on applying the chain rule to find the derivative of temperature, T, at points on the upper half of the unit circle, parametrized by x = cos(t) and y = sin(t) for 0 ≤ t ≤ π. The partial derivatives are given as ∂T/∂x = 4x - 2y and ∂T/∂y = -2x + 4y. The correct expression for ∂T/∂t is derived as ∂T/∂t = 2(sin²(t) - cos²(t)). The user initially confused the first and second derivatives but ultimately corrected the mistake, confirming that setting the first derivative to zero is essential for finding maximum and minimum temperatures.
  • Understanding of partial derivatives and their applications
  • Familiarity with the chain rule in calculus
  • Knowledge of parametrization of curves
  • Basic concepts of single-variable calculus
  • Study the application of the chain rule in multivariable calculus
  • Learn how to parametrize curves in different contexts
  • Explore techniques for finding extrema using first and second derivatives
  • Investigate the implications of temperature gradients in physical systems
Students studying calculus, particularly those focusing on multivariable functions and their applications in physics and engineering.
sikrut
Parametrize the upper half of the unit circle by [itex]x = cos(t), y = sin(t),[/itex] for [itex]0\leq t \leq\pi[/itex]
Let [itex]T = f(x,y)[/itex] be the temperature at the point [itex](x,y)[/itex] on the upper half of the circle.
Suppose that:
[tex]\frac{\partial T}{\partial x} = 4x - 2y[/tex] [tex]\frac{\partial T}{\partial y} = -2x + 4y[/tex]
Using the given parametrization and the chain rule, find the derivative [itex]\frac{\partial T}{\partial t}[/itex]. Then:
(a) Using methods of single-variable calculus, find where the minimum and maximum temperatures occur on the upper half circle:
When t = [______], and this occurs at the point [itex](x,y)[/itex]=(__,__)
(b) Find the maximum and minimum values of the function: [tex]2x^2 - 2xy + 2y^2[/tex]
on the upper half of the unit circle.
[tex]\frac{\partial T}{\partial t} = \frac{\partial T}{\partial x}\frac{dx}{dt} + \frac{\partial T}{\partial y}\frac{dy}{dt}[/tex]
[tex]\frac{\partial T}{\partial t} = (4x - 2y)\frac{dx}{dt} + (-2x + 4y)\frac{dy}{dt}[/tex]
[tex]\frac{\partial T}{\partial t} = (4x - 2y)(-sin(t)) + (-2x + 4y)(cos(t))[/tex]
[tex]\frac{\partial T}{\partial t} = -4xsin(t) + 2ysin(t) - 2xcos(t) + 4ycos(t)[/tex]
[tex]\frac{\partial T}{\partial t} = -4cos(t)sin(t) + 2sin^2(t) - 2cos^2(t) +4sin(t)cos(t)[/tex]
[tex]\frac{\partial T}{\partial t} = 2(sin^2(t) - cos^2(t))[/tex]
So I found [itex]\frac{dT}{dt}[/itex] like the problem asked. Then, using "single variable calculus," I found the second derivative ([itex]\frac{d^2T}{dt^2}[/itex]) and set it to zero to find the maximum and minimums.
Those turned out to be [itex]\frac{d^2T}{dt^2} = 0 = [0,pi/2,pi][/itex]
I plugged in the values, but the result comes back as in correct. What am I doing wrong?
Suppose that:
To find a min/max for temperature, T, set its 1st derivative to zero !
Ah, yes. That would be the logical thing to do wouldn't it? :blushing:
Right as I sent that question, I realized where I messed up.
[tex]\frac{d^2T}{dt^2}[/tex] is not the second derivative of [tex]\frac{dT}{dt}[/tex].
I should have derived one more time.
Stupid mistakes..
Thanks for your reply though. I did it both ways just to see and they both work.
  • · Replies 17 ·
