| New Reply |
Polarity switching electromagnet |
Share Thread | Thread Tools |
| Sep10-12, 03:27 PM | #1 |
I wanna make an electromagnet to rapidly switch polarity back and forth. I hear the core should be made of laminated iron to avoid heat losses; is this correct? Where could I get one such core from, and is there anything else I should consider?
| Sep11-12, 04:54 PM | #2 |
Well since power transformers are laminated and do switch polarity efficiently, I would suggest you look around for surplus, burned out or otherwise unwanted power transformers and take your parts from that. (you can use the copper wire if you can get it out in usable lengths.) AC electric motors have laminated cores also.
You are familiar with the problems involved in driving an inductive device with a switched signal with a fast rise time? DC |
| Sep12-12, 09:21 AM | #3 |
| Sep12-12, 09:49 AM | #4 |
Recognitions:
Polarity switching electromagnetThe inductor equation, v=L.di/dt shows that if you want a high value of di/dt, you have to apply a high v. |
| New Reply |
| Thread Tools | |
Similar Threads for: Polarity switching electromagnet
| Switching polarity on electromagnets | General Physics | 6 | ||
| List the solids in order of increasing polarity. | Biology, Chemistry & Other Homework | 1 | ||
| Switching or not switching from Civil Engineering to Physics | Career Guidance | 6 | ||
| [SOLVED] Electromagnets and switching polarity? | Electrical Engineering | 7 | ||
