New Reply
Heat pump problem with heat loss?
Share Thread
Sep10-12, 05:05 PM   #1
Consider a heat pump used to heat a house to 70°F when the outside temp is 5°F. The total heat loss from the house is 10000 BTU/hr. Efficiency of the heat pump is 45% of the theoretical maximum. What will be the power used by the pump?
2. Relevant equations
e (or cop) = Q_H/W
ideally, e = 1/(1-T_C/T_H)
3. The attempt at a solution
I am given to understand that a heat pump is a kind of refrigerator, which is a heat engine run backwards...what I don't understand is what to do with the heat loss I am given. I have absolutely no idea where the heat lost from the house would fit into the equations. Which leaves me stumped on where to even begin to start finding the work. Which is what I'm assuming is meant by "power"; however, I am not sure about that, either.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep10-12, 05:27 PM   #2
The heat from the house is lost into the atmosphere. Consequently the heat pump has to pump as much heat back into the house to keep the temperature inside constant.
Sep11-12, 03:05 AM   #3
To maintain equilibrium (eg constant temperature) the heat coming in must equal the heat going out.
New Reply
Similar discussions for: Heat pump problem with heat loss?
Thread Forum Replies
Heat engine and Heat pump in combination Engineering, Comp Sci, & Technology Homework 3
Pool heat gain by solar radiation versus heat loss by evaporation General Physics 2
Temperature Fusion (heat gain = heat loss) Introductory Physics Homework 8
How much energy to heat a room, and heat pump efficiency? Classical Physics 3
Heat Equation Time dependant heat loss Calculus & Beyond Homework 1
