Can Electrical Resistance be Measured Along Meridians and Parallels?
  • Thread starter Thread starter Numeriprimi
The discussion revolves around measuring electrical resistance along the Earth's meridians and parallels, specifically between the poles and between two equatorial nodes. Participants explore the implications of electric potential and the configuration of wires in this context.
  • Participants question how to calculate resistance in different configurations, considering the number of wires and their arrangement. There is discussion about whether to treat certain connections as parallel due to equal potential. Some participants suggest that the problem may require approximations or additional assumptions.
The discussion is ongoing, with participants offering insights into the symmetry of the problem and the behavior of current in relation to the wires. There is an acknowledgment of the complexity of the calculations involved, and some participants are preparing to further analyze the problem through calculations and drawings.
Participants note the classical division of the Earth into 24 meridians and parallels, which may influence their calculations. The resistance value is described as unknown and proportional to length, but its specific impact is under consideration.
Numeriprimi
Hello.
I am sorry for my English, because I am from the Czech Republic.
I have an example. I don't know how to calculate it. Can you help me?
Along the meridians and parallels are stretched wires.
a) What electrical resistance we will measure between the Earth's poles?
What electrical resistance we will measure between two nodes, that lie on the equator and opposite each other?
I think, the first case, parallel can we deleted, because they intersect places with the same electric potential and count parallel connection.
But , I don't know... Can you help me?
Thanks very much :-)
Do you know the resistance of your wires?
How many wires are there?
The second equation might be messy or need some approximation or additional assumption.
Right
The resistance value is unknown, it is "q".
"q" is directly proportional to the length. However, leght is not important now.
Relevant is process.
How many wires... Classical system on Earth- 360/15=24--- 24 parallel, 24 meridians.
Hmmm... The second- Do you understand? Isn't it unintelligibly?
Ah, good. It can be solved with a big equation system and Kirchhoff's laws. Maybe there is some trick I do not see to simplify the problem.
I would expect some value comparable to the first one, probably larger by a factor of ~2-3.
The symmetry of the problem should be considered.
For the first case, the wires along the parallels should have zero current, shouldn't them?
All the points of the meridians have the same potential at the same latitude.
If there were current through the parallel lines, which way will go? East or West?
Tonight I will calculate and drawing this... then I will write somethink.
  • · Replies 24 ·
