| New Reply |
throws a stone horizontally with a velocity of 20ms-1 |
Share Thread |
| Sep12-12, 12:58 AM | #1 |
1. Don Joriel stands on a vertical cliff edge throwing stones into the sea below. He throws a stone horizontally with a velocity of 20ms-1, 560 m above sea level. a. How long does it take for the stone to hit the water from leaving Don Joriel’s hand? Use g = 9.81 ms-2 and ignore air resistance? b. Find the distance of the stone from the base of the cliff when it hits the water. 2. When Maggie applies the brakes of her car, the car slows uniformly from 15.00 m/s to 0.00 m/s in 2.50 s. How many meters before a stop sign must she apply her brakes? 2. Relevant equations 3. The attempt at a solution please help me with those problem, im confused. I am not sure if i got the correct answer. here are my answers 1. a. 2.04 s b. 20.39 m 2. 18.75 m Hope you can help me, if got the wrong answer please show me the solution... Thanks a lot... |
| Sep12-12, 01:18 AM | #2 |
Recognitions:
Show your calculations.
| Sep12-12, 01:25 AM | #3 |
Recognitions:
What rl.bhat said: if you don't show us what you tried or your reasoning, then we cannot know how to help you best.
| Sep12-12, 03:19 AM | #4 |
wait i'll show you when i got home.. thanks...
| Sep12-12, 04:44 AM | #5 |
for 1a. i use v = u + at,
b. s = ut +1/2 at squared for 2. s = 1/2 (u +v)t are those correct? |
| Sep12-12, 05:05 AM | #6 |
| Sep12-12, 05:17 AM | #7 |
For 1b, we are considering a horizontal distance. There is no acceleration of the ball in x direction so the eqn you were using simplifies to simply [itex] s = v_{ox}t [/itex].
For 2, if I understand the wording of the question correctly, you are correct. |
| Sep12-12, 05:23 AM | #8 |
| Sep12-12, 05:28 AM | #9 |
Recognitions:
| Sep12-12, 05:37 AM | #10 |
Yet another way is to do all three problems via sketching v-t diagrams for each of the x and y components of velocity. |
| Sep12-12, 05:54 AM | #11 |
what is the answer on the problem? i am totally confused.. please help me...
| Sep12-12, 05:56 AM | #12 |
| Sep12-12, 05:56 AM | #13 |
i got it already... thanks...
| Sep12-12, 05:58 AM | #14 |
how about number 2?
| Sep12-12, 06:00 AM | #15 |
Recognitions:
Can you find the time taken by a stone dropped from a height 560 m?
| Sep12-12, 06:04 AM | #16 |
| Sep12-12, 06:33 AM | #17 |
so t = 10.68... by the way where did you get 500? is it 560?
| New Reply |
Similar discussions for: throws a stone horizontally with a velocity of 20ms-1
| Reference frame, referential with motion, describe the motion of a particle/Coriolis | Advanced Physics Homework | 7 | ||
| Rigid Body - Linear (Center of Mass) motion/Rotational Motion | Introductory Physics Homework | 6 | ||
| Using Simple Harmonic motion and conservation of motion to find maximum velocity | Introductory Physics Homework | 3 | ||
| Important find:when is the light wave-motion ?and when is particle-motion? | Special & General Relativity | 5 | ||
| Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): | Introductory Physics Homework | 4 | ||
