Proving l a + b l < l 1 + ab l with l a l < 1 and l b l < 1
  • Thread starter Thread starter Andrax
The discussion revolves around proving the inequality |a + b| < |1 + ab| under the conditions |a| < 1 and |b| < 1. Participants are exploring the implications of these conditions and how they relate to the inequality.
  • Participants have attempted to manipulate the given conditions to derive the desired inequality, with some expressing confusion about the validity of their steps. There are discussions about squaring both sides of inequalities and the implications of absolute values. Some participants question the assumptions made in initial attempts, particularly regarding the product ab.
The discussion is ongoing, with various participants providing insights and alternative approaches. Some have suggested working backwards from the inequality or modifying arguments as needed. There is no explicit consensus yet, but several productive lines of reasoning are being explored.
Participants are encouraged to stay within the bounds of the given conditions |a| < 1 and |b| < 1 while exploring the problem. There are mentions of potential pitfalls in reasoning, particularly regarding the assumptions about products and sums of a and b.
Andrax
so this is the question I've trid my best (over 2 hours trynig this and failed) can someone please help me
show that :
l a l < 1 and l b l<1 => l a + b l < l 1 + ab l
just a little bit on info , you can only stay from the lal < 1 and lbl <1 side to get to the other one
here's what i tried so fay
l a l < 1 and l b l<1 => l a b l < 1
=> -1 < ab < 1
=> 0 < 1 + ab <2
=> l 1 + ab l <2
l a l < 1 and l b l<1 => -2 < a + b < 2
=> l a + b l < 2
yup I am pretty much stuck here..pleasee help(i can't say l a + b l < l 1 + ab l because they are both<2..
show that :
=> -1 < ab < 1
=> 0 < 1 + ab <2
=> l 1 + ab l <2
=> l a + b l < 2
Don't worry too much about staying on one side while you figure out what's going on. You can always modify your argument to fix that later. You can even work backwards while analyzing it. So far you have 0 < 1+ab, so your problem is equivalent to |a+b|<1+ab. Write that as$$
\sqrt{(a+b)^2} < 1+ab$$Square both sides and work on that. Once you see it, modify it by working backwards through the reversible steps.
if |a|=0.8 which is less than 1 and |b|=0.2 which is also less than 1 but |ab|= 1.6 which is greater than 1. so your very first line of the solution is wrong
|a|+|b| ? |a + b|
|a||b| ? |ab|
As LCKurtz says - don't worry about the rules while you are trying to understand the relations.
@KUMAR |0.8x0.2| = 0.16 < 1 isn't it?
kumar sidhant said:
if |a|=0.8 which is less than 1 and |b|=0.2 which is also less than 1 but |ab|= 1.6 which is greater than 1. So your very first line of the solution is wrong
##(.2)( .8) = .16##
thank you
tried this solution?
let us assume that
|a+b| < | 1+ab|
squaring both sides
a*a + 2ab + b*b < 1 + 2ab + a*a*b*b ----- 1
we have
|a |< |1|
square both side
a*a < 1
multiply with b*b it is positive and no change in inequality
a*a*b*b < b*b
adding 1 on both sides and 2ab
1 + 2ab +a*a*b*b < 1 + 2ab + b*b ---- 2
using 1 and 2
we have
a*a + 2ab + b*b < 1+ 2ab + b*b
which boil down to
a*a < 1 which is true
I do not know whether this approach is right or wrong
let us assume that
|a+b| < | 1+ab|
squaring both sides
we have
|a |< |1|
square both side
a*a < 1
a*a*b*b < b*b
using 1 and 2
we have
which boil down to
I would call that an exploratory argument. It shows you why the inequality works so you understand it. But to make a correct argument, you must start with something that is true and end up with your inequality. So your argument would start like this:
|a| < 1 is given
|a|2 = a2 < 1 ...
Continue by reversing your steps and ending up with what you were to prove.
|a| < 1 is given
|a|2 = a2 < 1 ...
thanks again i think i got it :)
Hint:
If [itex]a = 0[/itex] or [itex]b = 0[/itex], then the identity is surely satisfied (why?).
If [itex]a \neq 0[/itex] and [itex]b \neq 0[/itex], then [itex]\vert a \, b \vert > 0[/itex]:
Apply the triangle identity for the absolute value to:
[tex] \left\vert \frac{1}{a} + \frac{1}{b} \right\vert[/tex]
and multiply both sides of the inequality by [itex]\vert a \, b \vert[/itex].
  • · Replies 21 ·
  • · Replies 22 ·
