Modelling A Stiff Base With A Mass Spring System
This discussion focuses on modeling the collision of a moving object with mass m1 against a stationary base using a mass spring system with damping. The user seeks guidance on selecting an appropriate damping coefficient for the collision of two steel objects, specifically chrome-moly. The conversation highlights the use of an "infinitely" stiff spring to represent the stiff base and suggests employing two different spring constants: one for the approach phase and a softer one for the separation phase. Additionally, it emphasizes the relationship between energy removal and the coefficient of restitution in rigid body collisions.
  • Understanding of mass spring systems and their dynamics
  • Knowledge of damping coefficients and their effects on motion
  • Familiarity with the coefficient of restitution in collisions
  • Basic principles of energy conservation in mechanical systems
  • Research methods for calculating damping coefficients in mass spring systems
  • Explore the concept of the coefficient of restitution and its application in collisions
  • Learn about energy dissipation in mechanical systems and its impact on motion
  • Investigate the use of multiple spring constants in dynamic simulations
Mechanical engineers, physicists, and anyone involved in modeling dynamic systems or studying collision mechanics will benefit from this discussion.
pollytree
Hi all.
I am working on a problem in which I want to model the collision of a moving object, with mass m1, with a stationary base. I have calculated the velocity of the moving object at the instant of collision. I want to model this collision using a mass spring system with damping.
My idea was to model mass m1 on an 'infinitely' stiff spring to represent a stiff base. This would have an initial velocity that I calculated previously. Obviously the equivalent system will not be perfect, but an approximation is fine in this case. The issue I am having is with selecting a suitable damping coefficient.
As the moving mass hits the base there will be some vibration before it becomes stationary, i.e. reaches steady state. Hence there needs to be some damping.
Could anyone provide some indication it what I could do in this situation? I don't really have a feel for what would be a suitable damping coefficient. If it is of any use, I am modelling the collision of two steel objects (chrome-moly to be precise).
Thanks for your help! :)
One way to do this is use two different spring constants, one when the objects are approaching each other and a smaller one when they are separating. When you reduce the spring stiffnesss, you remove some of the potential energy stored in the spring,
For a collision of two "eigid" objects you can relate the amount of energy removed to the coefficient of restitution between the bodies. Look at the KE of the bodies before and after the collision, and the difference is what you have to remove by softening the spring.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 45 ·
