Fizeau, 1851, drag coefficinet
  • Context: Undergrad
  • Thread starter Thread starter callejon
    Drag
Fizeau's 1851 experiment established the Fresnel drag coefficient, demonstrating the speed of light in moving materials. The discussion confirms that changing the direction of water flow in Fizeau's apparatus results in a proportional change in fringe patterns, specifically indicating that the change is indeed twice as much when comparing two directions of water flow versus one direction with no movement. Reliable sources on Fizeau's experiment are scarce, with misinformation prevalent online, making it essential to refer to original results for accurate understanding.
  • Understanding of the Fresnel drag coefficient
  • Familiarity with Fizeau's 1851 experiment
  • Basic knowledge of fringe pattern analysis in optics
  • Awareness of special relativity principles
  • Research Fizeau's original experimental results and methodology
  • Study the implications of the Fresnel drag coefficient in modern physics
  • Explore fringe pattern analysis techniques in optical experiments
  • Investigate the historical context of early experiments in relativity
Physics students, optical engineers, and researchers interested in the historical experiments related to the speed of light and the principles of relativity.
callejon
Has Fizeau changed the direction of the water in his experiment?
If no, wenn we change the direction of the water, is it true that we get twice as much change in fringes?
I mean, when we compare the fringes when there are 2 directions of water, is the change more than when we compare one dircetion and no movement of water?
Because I've never read that the direction of water was changed and my teacher says now that it was changed.
I haven't been able to find much in the way of reliable information on Fizeau's experiment. Google finds a bunch of crank webpages full of misinformation and little else. The sci.physics.faq on the experimental basis of relativity has only this to say:
http://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html#2. early experiments
Fizeau -- Measured the speed of light in moving materials. The Fresnel drag coefficient is solidly established by experiments, and is consistent with SR to within experimental resolutions.
callejon said:
is it true that we get twice as much change in fringes [..] when we compare the fringes [between] 2 directions of water[ versus] one dircetion and no movement of water?
Yes, that is the correct understanding but I don't know whether any particular person has bothered to perform that specific check (since there is no obvious reason to doubt it). On the other hand, why don't you just look up Fizeau's original results (using babelfish if necessary); wouldn't it be surprising if someone went to all the effort of preparing an appropriate apparatus and then only used it for flows in one direction?
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 24 ·
