Conservation of linar momentum - variable mass
The discussion revolves around the conservation of linear momentum in a system where a railroad car collects and expels water, examining how the mass change affects the car's velocity. Participants explore the implications of variable mass on momentum conservation, considering both theoretical and practical aspects of the scenario.
  • One participant questions whether the velocity of the railroad car decreases as it gains mass from the rain to conserve momentum, and whether the opposite occurs when water is expelled.
  • Another participant asserts that the velocity will decrease when mass is added but disagrees that it will increase when mass is removed, suggesting that work is done between the car and the incoming water.
  • A participant challenges the notion of work being done, asking what force acts on the car if the incoming water is vertical and the car's motion is horizontal, and discusses the implications of momentum conservation during inelastic collisions.
  • Another participant agrees that there is a force with a horizontal component acting on the water, which must correspond to an opposite force on the car, according to Newton's laws.
  • One participant introduces the equation F=dp/dt, explaining that a change in mass results in a force acting in the direction of or opposite to the velocity.
  • A later reply elaborates on the implications of mass flow across the boundary of a closed system, suggesting that the act of changing the system's boundary does not impose a physical force on the objects analyzed.
Participants express differing views on the effects of mass change on the car's velocity and the forces involved, indicating that multiple competing perspectives remain unresolved.
Participants highlight the complexity of the scenario, noting assumptions about external forces, the nature of inelastic collisions, and the implications of mass flow in a closed system, which remain open to interpretation.
StefanBU
If a railroad car traveling down a straight, frictionless track encounters vertical rain that fills it with additional mass, will the velocity decrease in order for the momentum to be conserved? Will the opposite happen if the water is let out from a hole in the bottom?
I cannot see any external forces to affect the system, but the fact that velocity is changing calls for acceleration, which calls for a force - I am having a hard time wrapping my mind around it. How can the velocity of the car change without any work being done?
yes
no
There is work done between the car and the incoming water.
What would the force against which work is done be? If the incoming water is vertical and the the car motion is horizontal, shouldn't there be a force with a horizontal component that does this?
If there is no such force, what would prevent the car from re-gaining it's original velocity once the mass is gone?
The way I have broken it down is - the incoming water entering the car is an inelastic collision: momentum is conserved but the overall kinetic energy is lower. Hence, to regain it work would need to be done on the car, which leaving water cannot do. Well, if we look at the leaving water, if no external force acted on it it would maintain the velocity of the car (which in reality it won't due to air drag, hitting the ground, etc.). Hence, the leaving water's momentum should be taken into account when establishing the momentum of the system, and velocity needs not to increase (in fact it cannot).
Please let me know if my reasoning is fallacious.
Of course there is a force with a horizontal component. The velocity of the incoming water is vertical and the velocity of the water in the car is horizontal. Therefore the water has been accelerated vertical and horizontal. According to the second law there must be a corresponding force acting on the water and according to the third law an opposite force acting on the car.
F=dp/dt, where p is momentum so when there is a change in mass it will also give rise to force and it will be in the direction of velocity or opposite to it.
In the usual case we have an otherwise-closed system with an external force being exerted on it. In such a case we can indeed derive F = dp/dt.
However, in the case at hand we have an otherwise-closed system with a mass flow going across the boundary. Or, equivalently, we have a boundary expanding or contracting to include or exclude some mass.
The act of expanding or contracting the boundary of an otherwise-closed system is done with pencil and paper or in the mind of the analyst. It does not impose a physical force on the objects being analyzed.
  • · Replies 30 ·
  • · Replies 53 ·
  • · Replies 30 ·
