Continuity in Metric Spaces: Proving the Convergence of a Sequence
  • Thread starter Thread starter gotmilk04
    Continuity Metric
The discussion revolves around proving the convergence of a sequence (f(x_n)) in the reals, given that (x_n) converges to a point x in a metric space (E,d). The problem touches on the concept of continuity in metric spaces.
  • Participants explore the implications of continuity for the function f and its effect on the convergence of the sequence (f(x_n)). There is a discussion about the necessity of continuity for the proof and examples are provided to illustrate potential pitfalls when f is not continuous.
The discussion is ongoing, with participants questioning the assumptions regarding the continuity of the function f. Some have pointed out that without continuity, the original poster's assertion may not hold true. There is an exploration of different scenarios and examples to clarify these points.
It is noted that the problem does not specify whether the function f is continuous, which is central to the discussion. This lack of information is causing uncertainty in the participants' reasoning.
gotmilk04
Show that if (x[itex]_{n}[/itex]) is a sequence in a metric space (E,d) which converges to some x[itex]\in[/itex]E, then (f(x[itex]_{n}[/itex])) is a convergent sequence in the reals (for its usual metric).
Since (x[itex]_{n}[/itex]) converges to x, for all ε>0, there exists N such that for all n[itex]\geq[/itex]N, d(x[itex]_{n}[/itex],x)<ε.
So |x-x[itex]_{n}[/itex]|<ε
I understand that this will prove continuity, but I'm not sure how to get from d(x[itex]_{n}[/itex],x)<ε to what we want: d(f(x[itex]_{n}[/itex]_,f(x))<ε
If f is continuous then from [itex]d(x,x_n)\rightarrow 0[/itex] you can deduce [itex]d(f(x_n),f(x))\rightarrow 0[/itex] (by definition).
Anyway for f general this might not be the case, take f(x)=1/x, x_n =1/n. x_n ->0 but f(0) is not defined.
We aren't given that f is continuous, which is why I'm stuck.
If f is not continuous, then the statement in the OP is false.
  • · Replies 17 ·
