New Reply
Motor resistance value isn't correct....
Share Thread Thread Tools
Sep18-12, 09:55 PM   #1
I have an electric motor that registers a .12 A draw off of a 2.76V source. This obviously indicates to you and me a resistance of 16.23 Ohms.
The problem is my Ohmmeter function on the MM. It reads out 1.2 between the motor leads, and this arithmetically can't be so.
There was a split second when the ohmmeter spiked to about 16.3 Ohms, but only for a split second, and then fell back to 1.2 Ohms.
Any advice to as why the meter is showing this impossible reading? ( OK, not impossible, but you get the idea.)
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Sep19-12, 03:16 AM   #2
Recognitions:
A motor is not a resistor and therefore it does not follow the V = RI.
Google "back emf"
Sep19-12, 05:29 AM   #3
Recognitions:
Gold Membership Gold Member
The motor needs to be running for it to take only 0.12A at 2.76V. When it is stalled, it can pass much more current (and can burn out).
Sep19-12, 10:28 PM   #4
Quote by uart View Post
Google "back emf"
Ohhh. I see. So the reading I am getting is commutator touching the coils of wire?
I am a spring chicken when it comes to electronics. I am currently taking an AC/DC course at my technical school. So excuse my Newbie sense of direction.
Sep20-12, 12:08 AM   #5
Recognitions:
I get 23 ohms for this.
Anyway, the motor generates "back EMF" when it is turning and this opposes the supply voltage to reduce the supply current.
If the figure of 1.2 ohms was correct, the motor would draw 2.3 amps when it was not turning. ( 2.76 volts / 1.2 ohms = 2.3 amps). This is why it is not a good idea to stall an electric motor.
Sep20-12, 02:13 AM   #6
Hmm, I think the reason the reading spiked to 16.3 ohm for a brief period is your probes were not touching the terminals properly. It may be caused by a jerk while taking reading.
Oct2-12, 06:37 PM   #7
Quote by vk6kro View Post
I meant a current of .170 A
New Reply
Thread Tools
Similar Threads for: Motor resistance value isn't correct....
Thread Forum Replies
Resistance of an electric motor Introductory Physics Homework 3
Need to choose DC motor with correct specs Classical Physics 1
Resistance of DC Motor Experiment Introductory Physics Homework 2
winding resistance of large motor vs small motor Mechanical Engineering 2
Motor Resistance Introductory Physics Homework 2
