Calculating Work Function: Light Sources & Photoelectrons
The problem involves calculating the work function of a metal based on the maximum kinetic energy of photoelectrons ejected by two different light sources with varying wavelengths. The context is rooted in the photoelectric effect and involves concepts of energy, wavelength, and frequency.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply the equation relating kinetic energy, frequency, and work function but is unsure how to incorporate both light sources into a solution. They question whether to set up two separate equations.
Some participants affirm the approach of creating two separate equations to solve for the work function, indicating a productive direction in the discussion. There is an acknowledgment of the need for multiple equations due to the presence of two unknowns.
The original poster expresses uncertainty about how to proceed with the problem, indicating a potential gap in understanding how to apply the equations effectively in this context.
phy
A light source of wavelength lambda illuminates a metal and ejects photoelectrons with a maximum kinetic energy of 1.00 eV. A second light source with half the wavelength of the first ejects photoelectrons with a maximum kinetic energy of 4.00 eV. What is the work functin of the metal?
I know I can use the equation for maximum kinetic energy defined by K=hf - phi where K is the maximum kinetic energy for emmitted electrons, h Planck's constant and f is frequency. Since we don't have frequency, I thought of rewriting the equation as K=hc/lambda - phi but now I don't know how to incorporate both light sources and to actually to solve for phi. Do I have to write two separate linear equations and solve them or is there something esle I'm supposed to be doing? Help please? :confused:
You have the right idea. Two separate equations and solve them. Go with it.
Bingo! :smile:
Any time you have two unknown quantities, you should suspect that you'll have to set up two equations for them, and solve them together.
Haha I just reread the question. I think I was having another blonde moment just a little while ago. Thanks for your help guys :smile:
  • · Replies 25 ·
  • · Replies 35 ·
