Efficiently Solving Diffusion-Based Equations Using Shooting Method in MATLAB
  • Context: MATLAB
  • Thread starter Thread starter baseball1234
    Method
This discussion focuses on solving diffusion-based equations using the Shooting Method in MATLAB. The user initially attempted to implement an explicit finite difference method but encountered issues with "NaN" results. Key parameters include grid points, time steps, and boundary conditions, specifically Neumann and Dirichlet conditions. The conversation highlights the need for stability checks on the numerical method employed, emphasizing the importance of adhering to the condition DG(dt)/dx^2 < 0.5 for stability.
  • Understanding of diffusion-based equations and their numerical solutions
  • Familiarity with MATLAB programming and its syntax
  • Knowledge of finite difference methods for solving differential equations
  • Experience with boundary condition types, specifically Neumann and Dirichlet conditions
  • Research the Shooting Method for solving boundary value problems in differential equations
  • Learn about MATLAB's built-in differential equation solvers, such as ode45 and ode15s
  • Investigate stability criteria for explicit finite difference methods in numerical analysis
  • Explore advanced plotting techniques in MATLAB for visualizing numerical results
Researchers, engineers, and students working on numerical methods for solving partial differential equations, particularly in fields such as chemical engineering and physics.
baseball1234
Hi, I have the attached diffusion based equations I am looking to solve, however I am unsure about how to implement. I have solved similar equations before, with a simplified r(cG,cO) using the explicit finite difference method and it worked fine. However, I am wondering if that would be OK for this set of equations. I read that people used shooting method to solve these, but I am unfamiliar with this method. Can I also use the differential equation solvers in MATLAB to do this? Thanks.
Hi, I have developed a program in MATLAB to solve these equations, however I was wondering if someone can take a look for me. My solutions are all coming out to be "NaN", which is "not-a-number" in Matlab. I am using the explicit finite difference scheme to solve. Any suggestions would be great. My code below will run in MATLAB from just a copy/paste from here. My boundary conditions are the following:
Code:
x = 0: dcG/dx=0, dcO/dx=0 and cH = 0
x = d: cG = cG0, cO = O20, cH = 0
 Initial conditions are
 cH(t = 0) = 0
 cG(t = 0) =cG0
 cO(t = 0) = O20
Code:
clear all;
numx =50;                       %number of grid points in space
numt =82000;                    %number of time steps to be iterated over
tmax = .06;
Length =50E-7;                  %length of grid
DG = 4E-10;                     %requirement DG(dt)/dx^2 < .5, cm^2/sec
DO = 5E-9;                      %requirement DO(dt)/dx^2 < .5, cm^2/sec
DH = 5E-9;                      %requirement DH(dt)/dx^2 < .5, cm^2/sec
Vmax = 60E-6;                   %A/cm^2
KG = 33E-6;                     %mol/cm^3
KO = .2E-6;
G0 =2E-6;                       %mol/cm^3 initial substrate concentration
O20 = .12E-6;                   %mol/cm^3 inital oxygen concentration
cG = zeros(numx,1);              %initialize everything to zero
cH = zeros(numx,1);              %initialize everything to zero
cO = zeros(numx,1);
zcG = linspace(0,Length,numx)';   %vector of x values, to be used for plotting
tG = linspace(0,tmax,numt)';      %vector of t values, to be used for plotting
zcO = linspace(0,Length,numx)';   %vector of x values, to be used for plotting
tO = linspace(0,tmax,numt)';      %vector of t values, to be used for plotting
zcH = linspace(0,Length,numx)';   %vector of x values, to be used for plotting
tH = linspace(0,tmax,numt)';      %vector of t values, to be used for plotting
dxG = zcG(2)-zcG(1);              %Define grid spacing in time
dtG = tG(2)-tG(1);                %Define grid spacing in time
dxO = zcO(2)-zcO(1);              %Define grid spacing in time
dtO = tO(2)-tO(1);                %Define grid spacing in time
dxH = zcH(2)-zcH(1);              %Define grid spacing in time
dtH = tH(2)-tH(1);                %Define grid spacing in time
S_Stability1 = (DG*dtG)/((dxG)^2) %check requirement DG(dtG)/dxG^2 < .5, cm^2/sec
O_Stability1 = (DO*dtO)/((dxO)^2) %check requirement DO(dtO)/dxO^2 < .5, cm^2/sec
H_Stability1 = (DH*dtH)/((dxH)^2) %check requirement DH(dtH)/dxH^2 < .5
Dirchelet Boundary Conditions, where Neumann BC dcG/dx=0 and dcO/dx=0
is in body of for loop below, IC is given by matrix initialization (zeros) and BC
cG(numx) = G0;                 %cG(x=d,t)=G0
cO(numx) = O20;                %cO(x=d,t)=O20
cH(1) = 0;                     %cH(x=0,t)=0
cH(numx) = 0;                  %cH(x=d,t)=0
%iterate central difference equation%
for j=1:numt %time loop
           cGlast = cG;
           cOlast = cO;
           cHlast = cH;
    for i=2:numx-1 %space loop
      cG(i) = cGlast(i) + (dtG/dxG^2)*DG*(cGlast(i+1) - 2*cGlast(i) + cGlast(i-1))-((Vmax*dtG*cGlast(i)*cOlast(i))/(cGlast(i)*cOlast(i)+(KG*cOlast(i))+KO*cGlast(i)));
      cO(i) = cOlast(i) + (dtO/dxO^2)*DO*(cOlast(i+1) - 2*cOlast(i) + cOlast(i-1))-((Vmax*dtO*cGlast(i)*cOlast(i))/(cGlast(i)*cOlast(i)+(KG*cOlast(i))+KO*cGlast(i)));
      cH(i) = cHlast(i) + (dtH/dxH^2)*DH*(cHlast(i+1) - 2*cHlast(i) + cHlast(i-1))+((Vmax*dtH*cGlast(i)*cOlast(i))/(cGlast(i)*cOlast(i)+(KG*cOlast(i))+KO*cGlast(i)));
      y(j,1) = cH(2);  %store data in vector for current plotting
    end
    cG(1)= cGlast(1)+dtG*DG*2*(cGlast(2)-cGlast(1))./dxG.^2; %Neumann Boundary Condition
    cO(1)= cOlast(1)+dtO*DO*2*(cOlast(2)-cOlast(1))./dxO.^2; %Neumann Boundary Condition
end
figure(1);
plot(zcH,cH);
xlabel('Length (cm)');
ylabel('[H2O2] (M)');
figure(2);
plot(zcG,cG);
ylabel('[Glucose] (M)');
figure(3);
plot(zcO,cO);
ylabel('[O2] (M)');
figure(4);
i = 2*(96500)*DH*(y/dxH);
%i = 2*(96500)*DH*(y/dxH);
plot(tH,i);
xlabel('Time (s)');
ylabel('Current (A)');
  • · Replies 41 ·
11K
9K
