Fundamental theorem for line integrals
The discussion centers around the fundamental theorem for line integrals, specifically its application to both vector fields and scalar fields. Participants explore the relationship between line integrals of scalar functions and the concept of path independence, as well as the visualization of these integrals in geometric terms.
  • One participant questions the analogue of the fundamental theorem for line integrals of scalar fields, suggesting that while scalar functions are not gradients, they could still be exact and have a potential function.
  • Another participant states that if "ds" is used, it implies a parameterization of the curve, leading to a standard integral form.
  • A participant introduces a generalized form of the fundamental theorem of calculus involving scalar functions and vector fields, indicating a relationship between line integrals and area integrals.
  • There is confusion regarding the interpretation of "dr" as a vector parameterizing the curve, with a participant providing an example using a circular path.
  • Discussion arises about the meaning of "dA" in the context of area elements and its relation to the line integral, with a participant clarifying that it pertains to the area of a surface bounded by the path of the integral.
  • Another participant agrees that "dr" can be expressed in terms of a parameter and discusses the use of dot and cross products in vector line integrals.
Participants express differing views on the application of the fundamental theorem to scalar fields and the interpretation of related concepts. There is no consensus on the visualization of vector field line integrals or the exact nature of the relationships discussed.
Participants express uncertainty regarding the definitions and interpretations of terms like "exact" and "potential function" in the context of scalar fields. The discussion also reveals a lack of clarity about the geometric visualization of vector fields compared to scalar fields.
dumbQuestion
Hi, I have a question. In my calculus book, I always see the fundamental theorem for line integrals used for line integrals of vector fields, where f=M(x,y)i + N(x,y)j is a vector field.The fundamental theorem tells me that if a vector field f is a gradient field for some function F, then f is path independent and then given a curve paramaterized by r(t) from a <= t <=b, ∫f°dr = F(r(a)) - F(r(b))However, what is the analogue of this for line integrals of scalar fields over the arc length of a curve? You know, the ol' ∫f(x,y)ds type of line integrals where f(x,y) is just a regular function of two variables? I know the gradient is a vector field, so clearly f here isn't a gradient, but it could still be exact (meaning there's a function F such that ∂F/∂x = ∂F/∂y). If that's the case, is F a potential function for f, and can I apply the fundamental theorem? Another issue I have is visualizing the problem. It's simple to visualize the line integral of a scalar field using arc length: it's just the "Area" of the "curtain" of f above the curve. But I can't for the life of me visualize the vector field version ∫Mdx +Ndy. But I know that for the vector field version, ∫f°dr = ∫f°Tds where T is the unit tangent vector so I know they're related by the tangent vector. How can I use the idea of the unit tangent vector to help visualize/understand the line integral of a vector field? The problem is my book just gives examples of physics and work, and to be honest, I just don't know anything about physics. How can I visualize it from a purely geometric perspective?
If you have "ds" then you have "s" as a parameter for the curve: x= g(s), y= h(s). So
[itex]\int f(x,y)ds= \int f(x(s), y(s))ds[/itex] which is just an ordinary integral.
[tex]\oint f(r) \; dr = -\int \nabla f(r) \times dA[/tex]
(for scalar [itex]f(r)[/itex], vector [itex]r[/itex], [itex]dr[/itex], [itex]dA[/itex].
All such integrals follow from the generalized fundamental theorem of calculus.
HallsOfIvy,I'm confused on what you're saying. When I was talking about "ds" I was talking about the change in arc length. In all the examples in my book, they end up paramaterizing the curve in terms of a variable t, so I end up with:
∫f(x,y)ds = ∫f(x(t),y(t))ds(dt/dt) = ∫f(x(t),y(t))(ds/dt)dt = ∫f(x(t),y(t))√(dx/dt)^2 + (dy/dt)^2) dt(t is paramaterizing the curve)
So when you say dr here, is that a vector r(t) which is paramaterizing the curve? (for example, if our curve was the portion of a circle of radius 1 in the first quadrant, we could have r(t)=<cost,sint> 0<=t<=∏/2
Then wouldn't we end up having:
∫f(r)dr = ∫f(r(t))dr*(dt/dt) = ∫f(r(t))(dr/dt)dt = ∫f(r(t))<-sint,cost>dt ? (I mean isn't this what the left hand side would be)
And as for dA on the right hand side, this is the change in area? I'm confused, the area of what?
Yeah, [itex]dr[/itex] could be taken equal to [itex](dr/dt) \; dt[/itex] for a scalar parameter [itex]t[/itex]. The same thing is done in vector line integrals; it's just that either you have a dot or a cross product between the vector field and [itex]dr/dt[/itex] in practice.
[itex]dA[/itex] is an area element of a surface whose boundary is the closed path of the line integral. If the path of the line integral is not closed, then there is no area integral on the right to compare against.
  • · Replies 20 ·
  • · Replies 20 ·
