How to Define Lattice Properties for Octagonal PCF in OptiFDTD 8?
The discussion revolves around the design of a supercell lattice for photonic crystal fibers (PCF) using OptiFDTD version 8. Participants explore the necessary parameters and methods for simulating various properties of the PCF, including dispersion and confinement loss, while referencing specific academic papers for guidance.
  • Homework-related
  • One participant seeks urgent assistance in designing a supercell lattice for a PCF.
  • Another participant asks for clarification on the material and wavelength range for the PCF design, suggesting that the design purpose influences the approach.
  • A participant provides links to potentially useful resources and papers related to PCF design.
  • One participant expresses a desire to calculate specific properties (dispersion, confinement loss, effective index) for the supercell arrangement using OptiFDTD, indicating familiarity with basic PCF structure design but confusion regarding supercell parameters.
  • Another participant offers a series of questions to help clarify the design process, suggesting that if the standard PCF can be simulated, the transition to a superlattice design should be manageable.
  • Concerns are raised about the implementation of the supercell in OptiFDTD, specifically regarding the replacement of cells and the definition of lattice properties.
  • A participant mentions successfully designing the supercell but encounters issues with running the simulation due to parameter settings.
  • Finally, a participant reiterates the need for urgent assistance in defining lattice properties for an octagonal PCF structure in OptiFDTD.
Participants express varying levels of understanding and familiarity with the software and design process, leading to multiple competing views on how to effectively implement the supercell lattice. The discussion remains unresolved regarding the specific steps needed to define lattice properties for the octagonal PCF.
Participants reference specific academic papers and software capabilities, but there are limitations in shared knowledge about the OptiFDTD software, leading to uncertainty in the design parameters and simulation processes discussed.
dimplebansal
Need on urgent basis as to design supercell lattice of pcf
Science news on Phys.org
Welcome to these forums.
PCFs based on which material? For what wavelength range?
There are many different possibilities of how (and for which purpose) to design the pcf.
A standard review explaining the basics was given by Russell (Science 299, 358-362 (2003)). If you want more details, you might have to ask a more specific question.
This link could be useful.
Ok,
I want to design a pcf based on supercell arrangement based on air channel with refractive index 1.45 of core air dielectric ie i want to simulate a ieee paper i m writing its name...
Progress In Electromagnetics Research M, Vol. 11, 53{64, 2010
SUPER-LATTICE STRUCTURE PHOTONIC CRYSTAL
FIBER
D. Chen y, M.-L. V. Tse, and H. Y. Tam
Photonics Research Centre, Department of Electrical Engineering
The Hong Kong Polytechnic University
Hung Hom, Kowloon, Hong Kong SAR, China
the second paper is
Supercell lattice method for photonic
crystal fibers
Wang Zhi, Ren Guobin, Lou Shuqin, and Jian Shuisheng
Institute of Lightwave Technology, Northern Jiaotong University, Beijing 100044, China
zhiwang@center.njtu.edu.cn
Ok, so you actually want to do the math and simulate the pcf behavior and most probably the field inside and the far field instead of actualyy manufacturing the fiber?
There are several software packages out there which can be used for that purpose. I will not spell out there name as I do not want to advertise anything. You can find them easily by performing a google search for photonic crystal fiber design software. However, they are rather expensive if you do not already have a license. Some have short term trial versions which may help you for a short time. There are also some free alternatives like this one: http://webee.technion.ac.il/people/leviatan/smtp/index.htm or this one: http://sydney.edu.au/science/physics/cudos/research/mofsoftware.shtml, but they are typically a bit more complicated and less convenient than their commercial counterparts.
thats so nice of u...
bt i actually want to calculate dispersion, confinement loss, effective index, etc for the supercell arrangement using Optifdtd software version 8...bt the thing is that i know how to design basic pcf structure using this software bt problem lies in the design of supercell arrangement as mentioned above in two papers i have quoted...i'm nt understanding the design parameters...
Dimple
Ok, so you have the software and the problem lies in implementing the supercell.
I am not familiar with the software you use, so let me ask you a few questions:
1) Are you able to simulate the standard PCF structure as shown for example in figure 1)b) of the first paper you linked?
2) If so, it should be no problem to design the easiest superlattice design shown in figure 1)a). Basically the innermost ring of the standard design consists of seven holes placed in a hexagonal fashion (minus the defect placed in the center of the PCF). Now all you need to do is to replace every single one of these holes with such a hexagonal structure of seven smaller holes of smaller diameter d' and smaller pitch. I do not know how to script that using your software, but if you can script the standard PCF, this version should be straightforward.
3) The elliptical structure is a bit more delilcate, I suppose, but you should postpone that anyway until you managed to simulate the superlattice PCF discussed in step 2).
bt the problem is the same na...how to replace the cell using OPTIFDTD
Is that such a problem? Typically if you have defined some 2D hexagonal lattice you should have the crystal lattice properties dialog box and inside it you should have some section about "atom waveguides in unit cell". Typically it should be this property you need to change.
I am not familiar with that program, but either it should have an option to use some sublattice as the atom waveguide in the unit cell or you should be able to create seven small atom waveguides in this unit cell, each having a shifted origin so that they are arranged evenly around the center of the unit cell.
Ya i have done that i have succedded in the design but the design is not running for 1 time through 2D simulation parameters because this is essential to see the refractive index generation for further processing...
Again there is one another problem has arisen in the design of octagonal pcf structure as to how to define lattice properties for the same in optifdtd 8. Reply needed on urgent basis.
Dimple
  • · Replies 0 ·
11K
