New Reply
Calculating horizontal distance using angle and max height
Share Thread Thread Tools
Sep23-12, 03:53 PM   #1
The froghopper, Philaenus spumarius, holds the world record for insect jumps. When leaping at an angle of 58.0 above the horizontal, some of the tiny critters have reached a maximum height of 58.7 above the level ground.
A)What was the takeoff speed for such a leap?
I got 4.00 m/s which was correct.
B)What horizontal distance did the froghopper cover for this world-record leap?
I really am not even sure how to attempt this.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep23-12, 04:10 PM   #2
Quote by kgianqu2
Close! The answer should be 40 m/s. Use this form v_y = v_0 * sin(θ). Then, find d from this form:
v_f² = v_y² + 2ad
Quote by kgianqu2
Then, you will need to use this form:
v_x = v_0 * cos(θ)
This gives you the time. Now, find the time using this form: v_f = v_y + at [You need to use part (a) to answer this question!] Finally, using the value of v_x and the time you found (given v_y), find the horizontal distance traveled.
s = v_x * t
Sep23-12, 04:35 PM   #3
When I answered 4.00m/s, mastering physics said it was correct.
I am not sure how to get time, but is v_x=36.7?
New Reply
Thread Tools
Similar Threads for: Calculating horizontal distance using angle and max height
Thread Forum Replies
Projectile Motion with only the vertical/ horizontal height and angle given General Physics 2
Projective motion from a height, final velocity and horizontal distance Introductory Physics Homework 3
Max horizontal distance wrt variable angle Introductory Physics Homework 8
Max height-2 balls-1 straight up-the other horizontal at an angle? yikes! Introductory Physics Homework 1
max height given angle and distance Introductory Physics Homework 1
