Force Conversions - horinzontal vs vertical
  • Context: Undergrad
  • Thread starter Thread starter Michael B
    Force Vertical
The discussion clarifies the relationship between forces acting on static and dynamic systems, specifically regarding horizontal and vertical loads. When a mass is hanging from a vertical wire, the force is calculated using F = m * g, where g is 9.81 m/s². For a static horizontal load of 10 kg, the force is also 10 kg * 9.81 m/s², confirming that the conversion from kg to Newtons remains consistent regardless of orientation. Additionally, when a wall is accelerated in the negative x-direction, the net force is determined by the mass of the system and the acceleration applied, leading to a net force of F = Ma.
  • Understanding of Newton's Second Law (F = ma)
  • Knowledge of gravitational force (g = 9.81 m/s²)
  • Concept of static vs. dynamic equilibrium
  • Basic principles of force and acceleration in physics
  • Study the implications of static equilibrium in mechanical systems
  • Learn about dynamic systems and net force calculations
  • Explore the effects of friction on static and dynamic loads
  • Investigate the principles of acceleration in various coordinate systems
Physics students, mechanical engineers, and anyone interested in understanding the principles of force and motion in static and dynamic systems.
Michael B
Hi guys
Just seeking some clarification here as my prof has been very vague.
Say we have a mass hanging off a vertical wire - the force upon that wire will be by F =MA, (m x9.81)N. I understand this.
But say we had a wall upon which we put a static horinzontal load/force of 10kg of "push", would that in Newtons still be (10) x (9.81)N?
Ie is the kg to N conversion still the same for horinzontal loads?
2nd Q:
And say we then moved the wall aganist the direction - ie if the force is in the x direction and we move the wall in the -x direction is the only force then F=MA where a is the acceleration of the wall.
Im slightly confused as if the wall was static - we would have an 'effective' acceleration of 9.81m/s^2 (assuming i am correct above ) wheras say we move the wall in at 3.6m/s^2 we would actually have less force than if we only consided it static ( 9.81 > 3.6 etc)
Much appreciated.
Mike
In the first question, the system is static, so the force on the wall is equal to the force of gravity on the mass. There is a pull on the wall from the acceleration of the mass of m*g, but the staying power of the wall (friction, if you will) is balancing this out, so the net force on the wall is zero, that's why there is no acceleration.
In the second question, you are accelerating the wall at a. The hanging mass would also accelerate upward at a. There is a net force of Ma, where M is the mass of the entire wall + mass system.
Your misconception is that there is no "effective" acceleration in the first part. There is a force from the hanging mass of (m * 9.81)N, but there is no net force, so there is no acceleration. In the second part, there is acceleration and therefore a net force of Ma. The same force from the weight of the mass is acting on the wall, but now there is extra force pulling the wall in the -x direction, therefore, acceleration.
  • · Replies 202 ·
16K
  • · Replies 21 ·
  • · Replies 22 ·
