| New Reply |
Equilibrium of a constant speed |
Share Thread | Thread Tools |
| Sep23-12, 08:39 PM | #1 |
The model airplane in Figure 5.6 has a mass of 0.90 kg and moves at a constant speed on a circle that is parallel to the ground. The path of the airplane and its guideline lie in the same horizontal plane, because the weight of the plane is balanced by the lift generated by its wings. Length is 17 m. and speeds of 19 and 38. The toy plane goes around in a circle that is parallel to the ground, at constant speed. Is the plane in equilibrium? 2. Relevant equations 3. The attempt at a solution I know that having a net force of zero or centripetal force of zero allows to be at equilibrium. The centripetal force is also directed toward the center of the circle and net force is the vector sum of all the force components that point along the radial direction. |
| Sep23-12, 09:10 PM | #2 |
| Sep23-12, 10:11 PM | #3 |
TO get the centripetal force I used to equation F=(mV)/r
and I got 100 and 201... So it is not in equilibrium ? |
| Sep24-12, 05:39 AM | #4 |
I dont know why you have 2 speeds.....2 different cases? Anyway, if a net force is being applied to an object, can it be in equilibrium? BTW, the centripetal force is mv^2/r, the tension in the cable in this example.
| New Reply |
| Tags |
| centripetal foce, constant speed, equilibrium |
| Thread Tools | |
Similar Threads for: Equilibrium of a constant speed
| power needed to climb constant slope at constant speed | Classical Physics | 22 | ||
| Equilibrium constant vs rate constant - where kinetics meets thermodynamics?? | Chemistry | 9 | ||
| dynamic equilibrium - walking in constant speed | Introductory Physics Homework | 3 | ||
| equilibrium constant and rate constant | Materials & Chemical Engineering | 6 | ||
| Given equation for position with unkown constant, find the constant for given speed | Introductory Physics Homework | 1 | ||
