Energy required to keep a mass in the air
  • Context: Undergrad
  • Thread starter Thread starter zplizzi
    Air Energy Mass
The discussion revolves around the energy required to keep a mass, specifically an electric helicopter, suspended in the air. Participants explore theoretical calculations of power and energy in relation to hovering, considering factors such as efficiency, air dynamics, and the mechanics of lift.
  • One participant questions how to calculate the energy required per unit of time to keep a helicopter aloft, noting that while force is needed to counteract gravity, the work done may not be straightforward due to the stationary nature of the helicopter.
  • Another participant suggests calculating the kinetic energy imparted to the air by the rotor as a means to determine energy requirements.
  • A participant proposes a method of calculating energy based on the weight of the helicopter and the acceleration of air, but acknowledges the complexity and potential inaccuracies in this approach.
  • Discussion includes the variability of power requirements based on rotor size and air velocity, indicating that larger rotors can move more air at lower speeds, potentially reducing power needs.
  • Some participants reference empirical data from model helicopters and full-size helicopters to illustrate power-to-weight ratios, noting that real-world performance can differ significantly from simplified calculations.
  • One participant introduces the concept of Reynolds number and its relevance to scaling effects in aircraft, particularly in relation to model and man-powered aircraft.
  • Another participant presents hypothetical scenarios where no energy would be required to maintain altitude, such as in cases of very low-density helicopters or specific geometric configurations.
  • A later reply discusses the efficiency of multiple small helicopters compared to a single larger one, suggesting that distributed lift could be more effective under certain conditions.
Participants express a range of views on the energy requirements for hovering, with no consensus reached. While some agree on the importance of air dynamics and rotor efficiency, others propose alternative scenarios where energy requirements could be negligible or vary widely.
The discussion highlights limitations in assumptions regarding efficiency, air dynamics, and the complexities of real-world applications versus theoretical models. Participants note that factors such as rotor size, air velocity, and environmental conditions can significantly influence power requirements.
This discussion may be of interest to those studying aerodynamics, engineering principles related to flight, and the physics of lift and energy transfer in fluid dynamics.
zplizzi
Take for example an electric helicopter - to keep it suspended motionless in the air takes a force from the propeller(s) equal to the force of mass times gravity.
I would like to know the energy required per unit of time to keep this helicopter in the air, assuming 100% efficiency.
I'm not sure if this is even possible - I know that a watt is 1 joule per second, and that a joule is the force required to move 1kg 1 meter. However, since my object is at rest the equation W=FD states that there is no work done - and that there is no power (watts) required to keep it in the air.
However something has to counteract the force of gravity, my question is - is there a way to calculate the energy required to exert that force?
Thanks guys, this is just a theoretical question I was thinking about earlier.. my first post here too :D
Science news on Phys.org
You can calculate the kinetic energy put into the air by the rotor.
Ahh, that makes sense - I forgot to consider the air.
However, how would you calculate the energy per time unit?
Say the helicopter weighs 10N, to counteract that 1kg of air would have to be accelerated 10m/s^2 (F=ma).
Since K=1/2mv^2, would I take this in one-second chunks and say that every second 1kg of fresh air is accelerated to 10m/s, therefore 50J of work per second (50 watts)?
Well, since no work is being done on a stationary object, how much power is required to keep it aloft can vary widely. For a helicopter hovering (but not suspended by a cable!), power is a function of the kinetic energy change in the air. But force is due to change in momentum. And since momentum and kinetic energy are not proportional to each other, you can increase one while decreasing the other. So the power required can be highly variable.
To put a finer point on it: if you use a larger rotor, you can move more air at a slower velocity, requiring less power for the same change in momentum (force).
If that were correct then you could also use a larger but slower rotor and accelerate 10kg to 1m/s^2 as that also produces 10N... So every second 10kg is accelerated to 1m/s.
K = 0.5 * 10 * 1^2
= 5Joules = 5W
so clearly this approach is not correct, or at least not perfect. You need to know what velocity the air is actually doing. Even then it assumes all the energy put into the air is lost.
K = 0.5 * 10 * 1^2
= 5Joules = 5W
Yes - what it's missing is the power that you need to supply to a rotor to produce the 5W of 'useful' power.
I looked up the spec for a random model helicopter. It is 450g and has a 9Wh battery. If it can hover for 10min on a charge (pretty optimistic I reckon, as you can get 50% more flight time when not hovering) it would be using 54W. That compares with the couple of Watts that your simplified approach would yield. There are clearly a lot of factors involved!
CWatters said:
Looks like the model helicopter is operating at about 100W/Kg.
Figure 2.6 and the text at the following link says that full size helicopters operate up to about 5kg/kW = 200W/Kg. That's only a factor of two difference which is less than I expected.
http://books.google.co.uk/books?id=...A65#v=onepage&q=power to hover per kG&f=false
I found that article too and that's where I got my 50% extra consumption for hovering, I think.
There is another factor which we haven't mentioned and that is the scaling. If you go down another order of magnitude or two (i.e. bumblebees and the like) they find that the viscosity of the air allows them to use much less 'fuel' for flying and hovering. I wonder whether this could affect a model aircraft. Perhaps not.
For medium speed aircraft the "Reynolds number" is a constant that attempts to account for scaling effect.
http://www.mh-aerotools.de/airfoils/howdoi.htm
Does indeed effect model aircraft as they operate at low Reynolds numbers (due to small size) and man powered aircraft (due to slow speed) compared to full size aircraft.
Hi.
No energy is required to maintain the height of your helicopter in cases:
- the weight of helicopter is so tiny that its density is same as that of air.
- top lid of a cylinder, the role of the helicopter plays. No air leak away from the cylinder thus the pressure of air inside the cylinder sustain the height of the helicopter.
- the shape of helicopter is thin sphere and big enough to cover whole Earth surface. no air leaks again so that air pressure sustain the height.
Regards.
This force the helicopter exerts on the air.
The energy used by the helicopter is the force times the distance that the air moves.
10000 toy helicopters keep their 5000 kg mass suspended in the air more effectively than 1 real helicopter that has a mass of 5000 kg. Air moves faster - less efficient, air moves slower - more efficient.
So ten thousand bumblebees could possibly lift me? Organising it could be a problem though. The argument makes sense, though. If a lot of toy helicopters could be spaced out so they were all working in 'clean' air, with no downdraft due to the others, then they would actually be covering a massive area of sky - much more than a single full scale one.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 25 ·
9K
