Need Help with Projectile Motion Homework?
This discussion focuses on solving projectile motion problems in an Honors Physics I class. The first problem involves calculating the horizontal distance a rock travels after being kicked off a 20 m ledge, using the formula ΔY=1/2(a)(Δt)^2 to find Δt, which is approximately 2.0 seconds. The second problem requires determining the time of flight for a long-jumper with an initial velocity of 12 m/s at a 28-degree angle, where the vertical and horizontal components of velocity are calculated as Vy,i = 5.6 m/s and Vx = 10.6 m/s, respectively. The discussion highlights the need for initial horizontal velocity to determine the horizontal displacement accurately.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations, specifically ΔY=1/2(a)(Δt)^2
  • Knowledge of vector components in physics, including sine and cosine functions
  • Basic grasp of free-fall acceleration, specifically -9.8 m/s²
  • Study the derivation and application of kinematic equations in projectile motion
  • Learn how to resolve vectors into their components using trigonometric functions
  • Explore the concept of initial horizontal velocity and its impact on projectile trajectory
  • Investigate advanced projectile motion problems involving varying angles and velocities
Students in physics courses, particularly those studying projectile motion, educators teaching physics concepts, and anyone seeking to improve their problem-solving skills in kinematics.
gabbiem10
I am in an Honors Physics I class at my school and we are just starting to learn about projectile motion. I am having a bit of trouble with some homework and am in need of help.
Problems:
1. I kick a rock horizontally off a ledge that is 20 m high. Once in the air, the rock is in free-fall. How far forward does the rock travel before hitting the ground?
A: I used ΔY=1/2(a)(Δt)^2 to solve for Δt if ΔY = 20m Vy,i = 0 m/s and
a = -9.8 m/s2. I got Δt ≈ 2.0s. Is it even possible to solve this with the given information?
2. A long-jumper leaves the ground with an initial velocity of 12 m/s at an angle of 28 degrees above the horizontal. Determine the long-jumper's time of flight.
I solved for the y component using Vy,i = Rsinθ and
Vx = Rcosθ. Vy,i = 5.6 m/s and Vx = 10.6 m/s. a = -9.8 m/s^2 but that was as far as I could get with the given information.
Problems:
1. Just a nudge, it won't go far forward. Forward depends on initial horizontal velocity.
2. Hidden data. Vertical displacement =0
The problem is that the initial horizontal velocity is not given neither is the horizontal displacement. The time was calulated base upon other given factors.
