| New Reply |
distributing into a square root |
Share Thread | Thread Tools |
| Sep25-12, 08:27 PM | #1 |
Its been a while since I have taken any kind of math class, I am a bit rusty in general algebra. Can someone explain how I would multiply an equation like this
(2x-1)sqrtof x-3x is it just like normal distribution? Would I just put the answer underneath the square root? sqrt2x^2-6x^2-x+3x? |
| Sep25-12, 09:09 PM | #2 |
all of these things are equal:
a*sqrt(b) = sqrt(a*a) * sqrt(b) = sqrt(a*a*b) |
| Sep25-12, 10:15 PM | #3 |
For example [itex]5 \sqrt{4} = 5 * 2 = 10[/itex]. But if you just put the 5 under the square root sign to make it sqrt(5*2) = sqrt(10), then that's not the same thing as 10 so you can't do that. Why not? Well, [itex]\sqrt{a^2b^2} = ab[/itex], right? That's because (ab)2 = a2b2. So, what's the fix? If we have 5 * sqrt(4) we can put the 5 under the radical by squaring it: [itex]5 \sqrt{4} = \sqrt{5^2*4} = \sqrt{100} = 10[/itex] as it should be. |
| Sep26-12, 12:18 PM | #4 |
Ok so let me know if im the right track if I have (9y+1)sqrt 82
i just square 9y+1 and put it under the square root with 82 and then times them both together? |
| Sep26-12, 03:23 PM | #5 |
In other words it is not always true that [itex]\sqrt{x^2} = x[/itex]. That's because the meaning of the square root symbol is the positive number that squares to what's under the radical. So if you start with x = -5, you'll end up introducing an error. Why do you want to put this expression under the radical? In general, doing so will change the meaning and introduce an error. |
| Sep26-12, 06:53 PM | #6 |
Ahh I see well I am finding the area of a surface and I need to distribute this expression into the square root due to the formula I was given
A= 2pi integral from a to b f(x)sqrt 1+ f(x) prime^2 that is the forumula that I have to use |
| Sep27-12, 07:12 AM | #7 |
I think you mean "f(x)sqrt(1+ f(x) prime^2)". Please use parentheses!
[tex]\int_a^b f(x)\sqrt{1+ f'^2(x)}dx[/tex] Yes, you can write that as [tex]\int_a^b \sqrt{f^2(x)(1+ f'^2(x))}dx[/tex] Whether that is a good idea or not depends upon f. |
| New Reply |
| Thread Tools | |
Similar Threads for: distributing into a square root
| F of G function question - Square root inside a square root? | Precalculus Mathematics Homework | 3 | ||
| Find derivative of Square root (x + square root(x + x^(1/2))) Help! | Calculus & Beyond Homework | 5 | ||
| Determine the exact value of.... (Square Root of Square Root) | General Math | 1 | ||
| Simplifying the Derivative of the Square Root of a Sum Containing a Square Root | Precalculus Mathematics Homework | 4 | ||
| prove that of sum square root of 2 and square root of 3 is not rational | Calculus & Beyond Homework | 15 | ||
