Is this number countably or uncountably infinite as m approaches infinity?
  • Context: Graduate
  • Thread starter Thread starter Eval
The discussion revolves around the nature of a mathematical expression as it approaches infinity, specifically whether certain sums and factorial expressions are countably or uncountably infinite. Participants explore the implications of different values of a in the context of cardinality and convergence.
  • Some participants propose that the sum \(\sum_{n=1}^{m}{(\frac{m!}{n!})^{a}}\) may be countably infinite, while others express uncertainty about this classification.
  • There is a suggestion that if \(a < 0\), the sum converges to 1, but the implications for \(a > 0\) remain unclear.
  • One participant questions the nature of the variable \(a\), asking whether it is an arbitrary real number or an integer.
  • Another participant argues that if \(a\) is positive, the sum is infinite, but if \(a\) is negative, it converges to a specific value.
  • There is a discussion about the cardinality of sets defined by \((m!)^a\) as \(m\) approaches infinity, with some questioning whether this cardinality is countable or uncountable.
  • One participant suggests that the ratio of cardinalities \(|S1|/|S2|\) could be irrational, depending on the nature of the sets involved.
  • Another participant asserts that infinity over infinity does not yield a rational or irrational number since it is not a number.
  • There is a correction regarding the expression for the sum, with a participant suggesting an alternative formulation that includes additional terms.
Participants express differing views on whether the sums and factorial expressions are countably or uncountably infinite, and there is no consensus on the implications of the variable \(a\) or the nature of the cardinalities discussed.
Limitations in the discussion include unclear definitions of the variable \(a\) and the conditions under which the sums converge or diverge. The implications of different values of \(a\) on the nature of the sums and their cardinalities remain unresolved.
Eval
How "big" is this number?
I have had absolutely no sleep for a while, so my math brain has been failing me. Last night, I was working on a problem and I believe that one of my connections is wrong. Is this number countably infinite or uncountably infinite (as m approaches infinity):
[itex]\sum_{n=1}^{m}{(\frac{m!}{n!})^{a}}[/itex]
I feel like it is countably infinite, but I am not sure.
Also, what about just simply (m!)a as m approaches infinity? If it is uncountable, that will be rather cool, too, as that is what one of my proofs hinge on.
There seems to be a little confusion. Numbers aren't countable or uncountable. Any particular number is just a number. The adjectives "countable" and "uncountable" refer to sets of numbers. So the rational numbers are countable, and the irrational numbers are uncountable. What that means is that the entire set of rationals is a countable set; and the entire set of irrationals is an uncountable set.
Does that make sense?
Also, what is a? Is it an arbitrary real? An integer? Or what?
If "a" is positive the sum is infinite, but if "a" is negative that is another story, but I feel that is infinite also.
If a < 0, the sum converges to 1.
The series is 1 + 1/m + {1/m(m-1) + 1/m(m-1)(m-2) + ... !/m!}
The part in brackets ~< 1/m, So the limit is simply 1.
The part in brackets ~< 1/m, So the limit is simply 1.[/QUOTET]
Thanks
Sorry, I am still blaming my lack of sleep for me not being clear. What I mean is something more along these lines...
If I have a set that has a cardinality of (m!)a as m approaches infinity and where a is some natural number >1, is the cardinality countable or uncountable? If the set is uncountably infinite, then could I say that:
S1 has a cardinality of the sum given in the first post
S2 has a cardinality of (m!)a (with the limit as m approaches infinity)
Then would |S1|/|S2| be irrational? If so, then would this show that ζ(s) is irrational for s>1 and is a natural number?
I argue that it would be irrational since |S1| is outside the set of integers and so is |S2|, so their ratio, in terms of c/d would not be the ratio of two integers, and thus not rational.
I don't think that infinity over infinity is either rational or irrational snce it is not a number.
If you have an infinite sequence of sets (a sequence necessarily being countably infinite), and each set is finite, then the union of the sets must be countable.
I believe you have a mistake, it should be:
(m!)^a+(m!/2)^a+(m!/3!)^a+...+(m!/((m-1)!))^a+1
but as you said for a<0, all the terms vanish as m->\infty except 1.
Raised to the power of -1 and reading from right to left, it is the same as Mathman wrote.
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 55 ·
11K
