How can we demonstrate hadrons in QCD must be color singlet?
  • Context: Graduate
  • Thread starter Thread starter ndung200790
    Color Qcd Singlet
The discussion revolves around the nature of hadrons in Quantum Chromodynamics (QCD), specifically addressing why hadrons must be color singlets and the implications of the Gauss law in this context. Participants explore theoretical aspects, constraints on physical states, and comparisons with Quantum Electrodynamics (QED).
  • Some participants question why color multiplet states of hadrons do not exist, suggesting that the coupling constant of strong interactions is only slightly greater than that in QED when quarks are close together.
  • Others express skepticism about the belief that only color singlet states exist in hadrons, asking for the basis of this belief and the definition of "colorless" states.
  • A participant explains that the Gauss law constraint implies all physical states must be color singlets, linking this to the concept of color confinement and the challenges in demonstrating that two-hadron states must also consist of singlets.
  • Some participants seek clarification on how to construct the Gauss law constraint that leads to the conclusion that the charge of physical states is zero, comparing this to scenarios in QED where electric charges are not necessarily zero.
  • There is a discussion about the distinction between total charge and charge density, with some participants asserting that the source of the electric field is the charge density rather than the total charge.
  • One participant elaborates on the mathematical formulation of Gauss's law as it applies to physical states, emphasizing that while physical states have vanishing total charge, they can still exhibit non-vanishing electric fields and charge densities.
Participants express differing views on the existence of color multiplet states and the implications of Gauss's law. There is no consensus on the foundational beliefs regarding color singlet states or the interpretation of charge in QED versus QCD.
The discussion includes unresolved questions about the assumptions underlying the Gauss law and its application to physical states, as well as the definitions of charge and color in different gauge theories.
ndung200790
Coupling constant of strong interaction is only finitely greater than coupling constant in QED if the quarks insides hadron not very far apart each other,so I do not understand why there are not exist color multiplet states of hadrons,other hand I do not understand why the singlet states have minimum energy(ground states).
Now I have heard that we can only believe that there are exist only color singlet states in hadrons.Then what base is for that believing?Why we know that the color singlet states are ''colourless''?
Using the Gauss law constraint Ga(x) |phys.> = 0 one finds that all physical states must be singulets w.r.t. this "local algebra". Integrating the Ga(x) this becomes Qa (up to surface terms), so one immediately deduces Qa |phys.> = 0.
Therefore all physical states are color singulets which is synonymous for colorless (a state with vanishing angular momentum is the same as an angular momentum singulet state). And hadrons are of course physical states.
So it's rather simple to deduce that a single-hadron-state must be a color singulet. What's difficult is to find a reason why a two-hadron-state must consist of two singulets, i.e. why a two-hadron-state with two colored hadrons is forbidden. This is color confinement and is the "really hard problem of QCD".
How can we ''build'' the Gauss law constraint with which the ''charge'' of physical states are zero?.Then I do not understand: despite that,why in QED (example) the electric charge in many physical states are not equal zero.
The Gauss law follows as an Euler-Lagrange equation in the A°=0 gauge (A° is unphysical b/c its conjugate momentum vanishes due to the absence of ∂°A° in the Lagrangian)
The electric field need not be zero; only the total charge must vanish.
What is ''total charge'' if it is not the ''charge'' that is the origin of electric field(the ''charge'' of U(1) symmetry?)?
The source of the electric field is not the total charge but the charge density which can be non-zero, of course.
Then the electric charge of an electron is not the ''total charge''?
The Gauss law as a field equation reads
[tex]G(x) = \nabla E(x) + \rho(x) \sim 0[/tex]
As an equation of constraint acting on physical states |phys> this becomes
[tex]G(x)\,|\text{phys}\rangle = 0[/tex]
Integrating the Gauss law (and omitting boundary terms - hand-waving ;-) this becomes
[tex]\int_{\mathbb{R}^3} d^3x\,G(x) = \int_{\mathbb{R}^3} d^3x\,[\nabla E(x) + \rho(x)] = \int_{\mathbb{R}^3} d^3x\,\rho(x) = Q[/tex]
Now we apply this charge operator to physical states Q which is
[tex]Q\,|\text{phys}\rangle = 0[/tex]
b/c it's nothing else but the integrated Gauss law constraint.
Therefore physical states have vanishing total charge, i.e. the eigenvalue of Q is zero in the physical Hilbert space. But they allow for non-vanishing electric fields and charge densities.
And of course this means that a single electron is NOT an physical state!
(the proof can be made more rigorous when treating boundary terms and operators more carefully)
EDIT: of course Q is the charge related to the U(1) symmetry; and the Gauss law is related to the generator of local U(1) gauge transformations
  • · Replies 46 ·
  • · Replies 0 ·
  • · Replies 0 ·
