Kinetic energy of electrons/protons
The discussion revolves around the kinetic energy of electrons and protons, specifically focusing on an electron acquiring 6.3 keV of kinetic energy while moving from point A to point B. Participants are exploring how much kinetic energy a proton would acquire under similar conditions and the ratio of their speeds at the end of their respective trajectories.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the assumption that a proton would also acquire 6.3 keV of kinetic energy due to its charge. Questions arise about how to calculate the ratio of their speeds, with some suggesting the use of energy conservation principles and equations for kinetic energy. Others mention the relevance of relativistic equations and the implications of mass on speed ratios.
The discussion is ongoing, with various approaches being explored. Some participants have provided insights into using relativistic equations, while others question the necessity of such methods. There is a mix of interpretations regarding the relationship between kinetic energy and speed, with no explicit consensus reached yet.
Participants are considering the context in which the electron acquires kinetic energy, with one questioning whether it is through an electric field. There are also references to classical versus relativistic interpretations of the problem.
thisisfudd
Hi, I'm working on the following:
An electron starting from rest acquires 6.3 keV of KE in moving from point A to point B. (a) How much KE would a proton acquire, starting from rest and moving to point A? (b) Determine the ratio of their speeds at the end of their respective trajectories.
So I understand that the proton will also have a KE of 6.3 keV because it has an equal but opposite charge to the electron (part A). But could someone give me a hint about the whole ratio of speeds part? Would I use some equation for velocity, and if so, how would I use the keV in it? Or do I use the respective masses of electrons and protons? Thx.
Use the relativistic equation
[tex]E = \gamma m c^2[/tex]
where m is the rest mass to find the velocities of e and p.
Think about energy conservation.
There talking about kinetic energy,
The equation for kinetic energy is
[tex]KE = \frac{1}{2} m v^2[/tex]
using conservation of energy, how would the KE of the electron compare to the KE of the proton?
edit: This is assuming your looking at it from the "classical" sense. If not, look to the post above
There's no need for relativistic formula,the ratio is approx 1/100 for the electron and 1/180000 for the proton (if the latter has the same 6.3 KeV).
Daniel.
I'm sorry Dexter, I don't think I understand what you're saying?? The answer, according to my friend, is something like 1:43. So I am looking for the ratio of their two velocities. This is dependent on mass, correct? Thanks.
Are we to assume that it acquires this KE by passing through an electric field? There are other ways it can acquire kinetic energy.
AM
I was making the ratio:
[tex](\frac{KE}{Rest \ mass \times c^{2}})_{electron} \sim \frac{6.3KeV}{511KeV}\sim \frac{1}{85}[/tex]
Well,i approximated (not too accurately,though) to 1/100 and called the use of relativistic energy formula a mere complication...
Daniel.
SUMMARY OF ESTABLISHED PROBLEM ITEMS:
[tex]:(1): \ \ \ \ (ElectronKineticEnergy) = (ProtonKineticEnergy) = (6.3 keV)[/tex]
[tex]:(2): \ \ \ \ \frac { M_{electron} V^{2}_{electron} } {2} = \frac { M_{proton} V^{2}_{proton} } {2} = (6.3 keV)[/tex]
{Electron Mass} = (9.1093897e-31 kg)
{Proton Mass} = (1.6726231e-27 kg)
  • · Replies 54 ·
12K
  • · Replies 21 ·
  • · Replies 44 ·
