Why does the water shoot up out of the straw at the top
  • Thread starter Thread starter Shay10825
    Water
The discussion revolves around a physics demonstration involving two soda bottles connected by straws, where water is observed to shoot out of the straw in the top bottle when inverted. Participants are trying to understand the underlying principles, particularly the role of pressure in this phenomenon.
  • Participants explore the concept of fluids in the system, questioning the presence of air as a second fluid. They discuss how pressure changes in both bottles affect the flow of water and air through the straw.
There is an active exploration of the relationship between pressure and fluid movement. Some participants express confusion about the mechanics of air and water interaction, while others provide insights into how pressure differentials drive the flow. Guidance has been offered regarding the behavior of fluids under pressure, but consensus on specific mechanics is still developing.
Participants are working within the constraints of a classroom demonstration and are attempting to clarify their understanding of fluid dynamics without complete information on the setup or the teacher's intended explanation.
Shay10825
Hi everyone :smile: !
My physics teacher showed us this thing he made and then asked us “why does the water shoot up out of the straw at the top”? No one knew the answer and he did not tell us the answer. And this has been bothering me for almost 2 weeks now (keep reading and it will make more sense . . . I hope).
My teacher took two soda bottles (you know the liter ones). He glued 2 straws in the inside of them and filled one about half way with water (i know this sounds really weird but the drawing will make more sense. . . hopefully lol). He glued them on top of each other and then turned it upside down so the one with the water is now on top. The water goes down into the bottle on the bottom but water shoots out of the straw on the top. Yeah I know your are probable thinking to yourself that this girl is crazy and makes no sense whatsoever lol. I'm sorry but it's hard to explain in words what he did. Why does the water shoot out of the top of the straw that is in the top bottle? What causes the water to shoot out of the straw? I know it has something to do with pressure. I hope the drawing makes more sense. lol :biggrin:
http://img76.exs.cx/my.php?loc=img76&image=water1gz.png
Any help would be greatly appreciated.
~Thanks
Well, there are two fluids in this system... can you tell me what happens to the other one as the water flows?
Two fluids?? There is only water. Some of it goes down into the other bottel and the rest shoots up the straw.
A fluid does not have to be a liquid. Look up the definition.
Is the other fluid air? And if so then as the water flows the air goes under the water?
Shay10825 said:
Is the other fluid air? And if so then as the water flowes the air goes under the water?
Correct and correct.
Now, what would "push" the air under the water and up thru the straw??
BTW ---> Compliments on your EXCELLENT ILLUSTRATION. Very nice!
Now, what would "push" the air under the water and thru the straw??
I have no clue. Could it be the air in the bottom bottle?
Thanks :biggrin:
What happens to the PRESSURE in the TOP bottle when water leaves??
What happens to the PRESSURE in the BOTTOM bottle when water enters??
The pressure in the top decreases and the pressure in the bottom increases?
CORRECT!
Fluids tend to flow from regions of higher pressure to regions of lower pressure. Now can you see what's happening?
not really. Why does the pressure make the air go under the water?
The TOP end of the Top straw (inside the Top bottle) will experience a LOWER PRESSURE than the BOTTOM end of the Top straw. Thus, air and water will be "pushed" through the straw from bottom to top (because fluids tend to flow from regions of higher pressure to regions of lower pressure).
ohhhhhhhh :smile: ! I understand now. Thanks :smile:
I still don't get what you mean by the "air will go under the water"...
I guess the air does not really go under the water. Everything just gets sucked up because it is going from high to low pressure. Right??
Is what I said correct?? Is it just being sucked up the straw or is the air going under the water and pushing it up the straw??
Both. The pressure in the top bottle is dropping. the pressue in the bottom is rising.
so it's really the air being sucked up and the air brings the water up with it?
So baisicly it is the same concept as if u have a emty bottle and took the opining and pointed it down then took it to the bottom of a pool it(the bottole) will shot up or as the diving platforms off the underside of a sub
____(air dispersese)
\_____ _______/
^(Water)
?Am i baisicly rite?
sry that's a bad diagram it was suppose to be baisicly the bottom side of a closed object(filled with) with an opening facing water
14K
  • · Replies 66 ·
