Prove Quadruple Product Identity from Triple Product Identities
The discussion revolves around proving the identity (a×b)·(c×d) = (a·c)(b·d) - (a·d)(b·c) using properties of vector and triple products. Participants are exploring the relationships between these products and how they can be applied to derive the desired identity.
  • Participants express uncertainty about how to begin the proof and discuss the use of scalar triple products. There are attempts to manipulate the expression by substituting variables and applying vector identities, but confusion arises regarding the steps and the direction of the proof.
Some guidance has been provided, including hints to use substitutions and the distributive law. Participants are actively engaging with the problem, but there is no explicit consensus on the next steps or a clear resolution yet.
Participants mention the need to prove the identity for application in a problem, indicating a practical constraint. There is also a recognition of the non-commutative nature of vector products, which adds complexity to the discussion.
jtleafs33
I need to prove the identity:
(a×b)[itex]\cdot[/itex](c×d)= (a[itex]\cdot[/itex]c)(b[itex]\cdot[/itex]d)-(a[itex]\cdot[/itex]d)(b[itex]\cdot[/itex]c)
using the properties of the vector and triple products:
a×(b×c)=b(a[itex]\cdot[/itex]c)-c(a[itex]\cdot[/itex]b)
a[itex]\cdot[/itex](b×c)=c[itex]\cdot[/itex](a×b)=b[itex]\cdot[/itex](c×a)
I really don't know where to begin. I need to prove this identity simply so I can use it on a problem, and I know it CAN be proven using these identities from the triple products, but I'm lost on how to attempt such a proof.
What have you tried?
Here's a hint:
Let u = c×d. Then use the scalar triple product, then substitute c×d back in for u, and see where that's leading you.
Added in Edit:
Putting in u, then applying the scalar triple product will simply let you switch a sclar product and a vector product, but that will allow you to get the desired result.
Okay, I did that, but I still am not understanding.
Letting u=(c×d):
(a×b)[itex]\cdot[/itex](c×d) = u[itex]\cdot[/itex](a×b) = b[itex]\cdot[/itex](u×a)
=b[itex]\cdot[/itex]((c×da)
=-b[itex]\cdot[/itex](a×(c×d))
=b[itex]\cdot[/itex](c(a[itex]\cdot[/itex]d)-d(a[itex]\cdot[/itex]c))
And I don't know what to do with this either...
Letting u=(c×d):
Use the distributive law to distribute the b vector. Don't forget, ad and ac are just scalars.
Right, I've got that:
b[itex]\cdot[/itex]c(a[itex]\cdot[/itex]d)-b[itex]\cdot[/itex]d(a[itex]\cdot[/itex]c)
Can I go from here to:
(b[itex]\cdot[/itex]c)(a[itex]\cdot[/itex]d)-(b[itex]\cdot[/itex]d)(a[itex]\cdot[/itex]c) ?
But this is backwards of the identity I'm after...
Letting u=(c×d):
The vector product is not commutative.
[itex]\textbf{r}\times\textbf{s}=-\textbf{s}\times\textbf{r}[/itex]
Fix that & you'll be OK .
Thanks! I had the negative sign there but forgot to carry it through the last step. Thanks for the help!
