Center of mass velocity greater than 1c?
The discussion revolves around the calculation of the center of mass velocity for two electrons moving towards each other at relativistic speeds. Participants explore the implications of special relativity on the calculations and the appropriate formulas to use for momentum and energy in this context.
  • One participant calculates the center of mass velocity using a specific equation and arrives at a value greater than the speed of light, prompting questions about the validity of the calculation.
  • Another participant suggests that the center of mass velocity should be calculated as an average of the two velocities, assuming a non-relativistic context.
  • Some participants challenge the energy calculations, asserting that the energy must exceed the momentum in relativistic scenarios, referencing the energy-momentum relation.
  • There are differing views on whether to use total energy or kinetic energy in the calculations, with some advocating for the use of the relativistic energy-momentum equation.
  • One participant mentions using the relativistic velocity addition formula to verify their calculations, indicating that the velocities in the center of mass frame should be equal in magnitude and opposite in direction.
  • Another participant expresses confusion over the application of non-relativistic assumptions in a relativistic context, highlighting the complexity of the situation.
Participants do not reach a consensus on the correct approach to calculating the center of mass velocity. There are multiple competing views regarding the application of relativistic principles and the appropriate formulas to use.
Some calculations appear to ignore relativistic effects, leading to confusion regarding the correct methodology. The discussion highlights the importance of distinguishing between relativistic and non-relativistic approaches in physics.
randombill
center of mass velocity greater than 1c?
Basically I have two electrons moving in opposite directions towards each other.
One is moving 2.5x10^8 m/s and the other is 2.0x10^8 m/s and I'm trying to use the
following equation for finding the center of mass velocity:
V_cm = ((p1 + p2)c^2)/(E1 + E2)
I calculated the momentum's and energies to be,
p1 = 456280 eV/c
p2 = 769846 eV/c
E1 = 174216 eV
E2 = 413132 eV
and the V_cm = 2.08756 c?
Is that supposed to happen, shouldn't it be less than 1?
I am not at all familiar with the formula you are using. However, the c.m. (since they are going in opposite directions) is moving at 0.25 x 10^8 m/s in the same direction as the faster electron.
Your p1 and p2 are correct, but E1 and E2 are not. How did you calculate E1 and E2?
Reality check: the energy in eV must be larger than the magnitude of the momentum in eV/c, because ##E^2 = (pc)^2 + (mc^2)^2##.
I used:
E_kin eV = (mass kg c^2(gamma -1))/(1.609E-19eV) (1)
Am I suppose to use the total energy including the kinetic energy so it would be:
E_total eV = (mass kg c^2(gamma +1)/(1.609E-19eV)) (2)
Or I'll just use ##E^2 = (pc)^2 + (mc^2)^2## instead. (3)
I got V_cm = .46c with equation (2), haven't tried (3) yet.
Yes, you need to use the total energy in v = pc2/E.
No, it's ##E = \gamma m c^2## not ##E = (\gamma + 1) m c^2##. And then your numeric factor to convert from joules to eV.
It's useful to remember that for an electron, mc2 = 5.11 x 105 eV = 511 keV.
When I know either the energy or the momentum, I always use ##E^2 = (pc)^2 + (mc^2)^2## to get the other one (provided I know the energy equivalent of the mass, of course, which is what Real Physicists [TM] always use anyway).
Well I tried it both ways now and got V_cm ~ .76c so that must be right. Using the momentum relation maybe the physicist's way of doing it but in the computer world using square roots are frowned upon. I'm writing this with C++ btw. The other way is much faster (without square root) and I would also guess more accurate although that is something else entirely different from this discussion. Thanks anyways; let me know if you think the velocity is wrong.
randombill said:
How did you calculate that btw?
The calculation ignores relativity. The electrons have the same mass, so the momentum is determined by the velocities. The center of mass velocity is simply the average of the two velocities. This assumes the problem is one dimensional.
Its interesting to do it that way but is it correct?
No, that's not it. I suspect that you didn't take into account that the two electrons are moving in opposite directions in your frame, so the momentum of one of them must be negative, whereas the energy is always positive.
No, it's not. I checked my answer by using the relativistic "velocity addition" formula to calculate the velocities of the two electrons in the c.o.m. frame. They come out equal in magnitude and opposite in direction, as expected.
In the center of mass system (two equal masses) the velocity should be equal and in opposite direction - I don't understand your objection to calculating the center of mass velocity as the average.
Ok I fixed it now I have the velocity of the first electron at .83c and -.66c for the second one and the final velocities are -.66c and .83c respectively. That makes more sense.
The arithmetic average of the velocities in the "lab frame" simply does not give v_cm in a relativistic situation. Calculate v_cm using the equation in post #1. The result does not equal the average of the velocities, (0.833c + (-0.667c))/2 = 0.083c.
Alternatively, use 0.083c as the velocity of a new reference frame, and use the relativistic "velocity addition" formula to calculate the velocities of the two electrons in that frame. They turn out not to be equal in magnitude (in opposite directions, of course), in that frame.
I've tried using "fraud mechanics" to get answers that are quasi relativistic but the problem lies within the energy-momentum relation and the fact that that equation works. Getting around that and getting a decent answer is impossible. Same goes for Newtonian mechanics with the work-energy theorem and the conservation of momentum, there is no way to simply fudge the formulas and get a decent result.
My comments were always in the context of a non-relativistic situation and I tried to make it clear.
In a relativistic situation, obviously it is somewhat more complicated.
No wonder I was confused. This is the relativity forum, after all.
