Please explain why I keep getting the incorrect moment about O
  • Thread starter Thread starter SlothNast
    Explain Moment
The discussion centers on calculating the moment of a 50 N force acting from point A (-15, -20) to point B (40, 10) using Varignon's theorem and a vector approach. The user correctly calculated the moments about the origin and point C (0, 25), arriving at a net moment of 519.5 Nmm CCW. However, the textbook provided an incorrect calculation of 179.6 Nmm, likely due to a mix-up in lever arm lengths and trigonometric functions. The user’s approach using Fx = F cos(theta) and Fy = F sin(theta) is validated as accurate.
  • Understanding of Varignon's theorem
  • Knowledge of vector decomposition of forces
  • Familiarity with trigonometric functions in physics
  • Ability to calculate moments and torques
  • Review Varignon's theorem applications in mechanics
  • Learn about vector cross product for torque calculations
  • Study the differences between sine and cosine in force decomposition
  • Explore common mistakes in moment calculations in physics problems
Students studying physics, particularly those focusing on mechanics and torque calculations, as well as educators looking for examples of common errors in moment analysis.
SlothNast
Please explain why I keep getting the "incorrect" moment about O
on the xy plane (in mm), there is a 50 N force that travels from point A (-15 , -20) , to point B (40 , 10). The first part of this question asks to find the moment of this force about the origin using Varignon's theorem. the second part asks to find the moment about a point C (0 , 25) using a vector approach.
theta = arctan (opp / adj)
M = (F)(d)
Fx = F sin(theta) (in my case, for you you can do cosine of complementary, same thing)
Fy = F cos(theta) (again, could do sine of complentary angle if desired)
Using Varignons theorem, I broke the force up at point A (going up, and going right, tail to tail). Then, I found the angle between the original force and the horizontal (28.6 degrees for me). Using this, I found that Fx = 43.9 N and Fy = 23.9 N. Since Fy is 15 units left of origin, I found the moment to be (23.9 N)(15 mm) = 358.5 Nmm CW. Then, I did the same for Fx and got (43.9 N)(20 mm) = 878 Nmm CCW. Using conventional directions, I found the net moment to be 878 - 358.5 = 519.5 Nmm CCW. This seems perfectly correct to me, but for some the book claims the correct answer is found by instead doing this.
(43.9 N)(15mm) - (23.9 N)(20 mm) = 179.6
This seems wrong to me, it looks they got the torque arm lengths mixed up, please tell me this seems to be the case, as I have been pulling my hair out all day trying to see why they did what they did.
Thanks
Your answer appears correct, which you can check using the T= r X F vector approach. Looks like they used the wrong lever arm or messed up sin vs. cos . You actually did Fx = F cos theta, and Fy = F sin theta, where theta = 28.6 degrees, which is correct.
  • · Replies 22 ·
  • · Replies 17 ·
13K
