More energy in bullets or batteries
  • Context: High School
  • Thread starter Thread starter Fezziwig
    Batteries Energy
The discussion compares the energy output of a bullet to that of an AA battery, focusing on kinetic energy and battery capacity. The kinetic energy of a bullet is calculated using the formula 1/2mv², while the energy of a battery is measured in watt-hours, with a conversion factor of 2.78 x 10-4 to convert joules to watt-hours. A standard AA battery's capacity is defined as the product of 20 hours multiplied by the constant current it can supply, typically rated at 100 A·h for a 20-hour discharge at room temperature. The discussion also highlights the difference between disposable and rechargeable batteries in terms of lifecycle and energy delivery.
  • Understanding of kinetic energy calculations (1/2mv²)
  • Knowledge of battery capacity and discharge rates
  • Familiarity with energy conversion between joules and watt-hours
  • Awareness of battery lifecycle characteristics for rechargeable batteries
  • Research the kinetic energy of various bullet calibers and their velocities
  • Explore the specifications and energy capacities of different AA battery brands
  • Learn about the lifecycle characteristics of rechargeable batteries
  • Investigate energy conversion methods and efficiency in batteries
Engineers, physicists, and anyone interested in comparing energy outputs of projectiles and batteries, particularly in applications related to energy efficiency and performance analysis.
Fezziwig
Are there more joules in a bullet or a battery (in it's lifetime). I'm afraid I don't know bullet calibres but we can assume that we're talking about an AA Battery.
Fezz: You related to the guy on 'That '70's show??'..Wilmer??
Anyway, why not figure it out?
the energy of a bullet is it's kinetic energy 1/2mv2
so pick some caliber and some speed...
and the energy of a battery, watt hours...
conversion: to convert joules to watt hours, multiply by 2.78 x 10-4
the usual standard for battery power is:
The capacity printed on a battery is usually the product of 20 hours multiplied by the constant current that a new battery can supply for 20 hours at 68 F° (20 C°), down to a specified terminal voltage per cell. A battery rated at 100 A·h will deliver 5 A over a 20-hour period at room temperature.
http://en.wikipedia.org/wiki/Battery_power#Battery_capacity_and_discharging
A typical dry cell battery can be discharged only once; a rechargable battery many times and if that is what you want to compare, you'll need to find it's life cycle characteristic...
how many times it can be discharged and recharged or it's lifetime power capability...
  • · Replies 29 ·
