Selection Rule delta_I = 1/2 in the strangeness-changing weak currents
  • Context: Graduate
  • Thread starter Thread starter zq460
    Currents Weak
The delta_I = 1/2 selection rule in strangeness-changing weak currents dictates that the ratio of the cross section for the proton to Sigma0 process compared to the neutron to Sigma- process is 1/2. This rule signifies that the change in isospin between the initial and final particles must be 1/2 for these specific processes. The discussion references the Cabibbo suppressed charged current processes, where a neutrino interacts with a nucleon, resulting in the conversion of a u-quark to a s-quark, leading to strangeness change (delta_S = 1). The relevant equations and details can be found in the referenced paper, particularly around equation (3.40).
  • Understanding of weak interactions in particle physics
  • Familiarity with isospin and strangeness quantum numbers
  • Knowledge of Cabibbo suppression in particle decay processes
  • Ability to interpret cross section ratios in particle reactions
  • Study the delta_I = 1/2 rule in K → ππ decay processes
  • Explore the implications of Cabibbo suppression in weak decays
  • Review the derivation of cross section ratios in weak interaction processes
  • Examine the role of W bosons in charged current interactions
Particle physicists, students studying weak interactions, and researchers focusing on strangeness-changing processes in high-energy physics will benefit from this discussion.
zq460
I read in a paper that delta_I = 1/2 rule of the strangeness-changing weak current implies the ratio of cross section of proton->Sigma0 process to neutron->Sigma- process to be 1/2. I do not understand what is this selection rule and how does it effect the cross section ratio of the 2 processes. Is delta_I = 1/2 rule is the change in the isospin of initial and final particle which has to be 1/2 for these processes? Will be great if somebody could explain. Thank you.
zq460, Could you be more specific about what reactions you have in mind? The only references I can find about a ΔI = 1/2 rule apply to K → ππ decay.
yes, I should have posted the reference paper. Sorry my first time ever on this forum. Here you can see an old paper http://nngroup.physics.sunysb.edu/~nngroup/misc/Documents/NeutrinoReactionsAtAcceleratorEnergies.pdf. The delta_I = 1/2 rule is mentioned just before equation (3.40) on page 317.
I am talking about the cabbibo suppressed 'charged current processes', where when a neutrino interacts with a nucleon, converts to a lepton producing a W-, which converts a u-quark in the nucleon to a s-quark. So this is a strangness changing process (delta_S = 1) where a 'proton converts to a Sigma0' or a 'neutron converts to a Sigma-', both processes are written in equation (3.39) and their cross section ratio is written to be 1/2 accodording to delta_I = 1/2 rule in equation (3.40). I do not understand the rule and also how it effects the ratio of the cross sections of the 2 processes?
Thanks much for the help!
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 49 ·
14K
