How to Generate Accurate Initial Conditions for Simulating Galaxy Dynamics?
This discussion focuses on generating accurate initial conditions for simulating disc galaxy dynamics using an N-body code. The user initially employed a Gaussian distribution for star positions and a Newtonian formula for velocities, but encountered instability in the galaxy's dynamics. Suggestions include incorporating a central bulge and adding a massive halo of invisible particles to enhance stability. The conversation emphasizes the need for more sophisticated models to achieve stable dynamics over time.
  • N-body simulation techniques
  • Gaussian distribution for spatial data
  • Newtonian mechanics for velocity calculations
  • Understanding of galaxy dynamics and stability
  • Research advanced N-body simulation techniques
  • Explore methods for incorporating a central bulge in galaxy models
  • Learn about the effects of dark matter halos on galaxy stability
  • Investigate velocity damping techniques in dynamic simulations
Astronomers, astrophysicists, and computational scientists involved in galaxy dynamics simulations and those seeking to improve the stability of N-body models.
fab13
Hello,
I'm trying to simulate disc galaxy dynamics with a nbody code. The main problem is to get
good initial values (positions and velocities of each star) in order to reproduce the
experimental dynamics.
For the positions, I began by generating a gaussian distribution of stars on 0x and Oy plans ( with mux=muy=0.0 and sigmax != sigmay). On 0z direction, I have generated a uniform distribution whose interval is small compared to sigmax and sigmay. ( this is supposed to reproduce the thin thickness of the disc galaxy). For the velocities of each point, I simply took the Newtonian formula :
vx = - ||vnorm|| * sin(theta)
vy = ||vnorm|| * cos(theta)
vz = 0.0
with ||vnorm||=sqrt(GM/R) with R equal to the distance from the origin and M the mass parameter that we have to adjust.
Unfortunately, using the code with these initial conditions, the galaxy is not stable from a dynamics point of view.
I know the model of these conditions is too basic. Could you give me indications to generate initial conditions more accurate, which could reproduce a stable dynamics.
For example, I should take account of a central bulge.
Has anyone got some documentation on this problem and models more elaborated ?
Thanks
Astronomy news on Phys.org
What do you mean by this: for how long should it remain stable, until it develops its spiral arms, or further than that?
In case you want to make it stable indefinitely, I think you should use some tricks, the most common is to add a massive halo of invisible particles to it.
||vnorm||=sqrt(GM/R) , won't that produce absurd velocities?
Maybe you could do a velocity dump after so many interactions, to see if they are very high or maxing out.
Personally I'd use (1+R), or to limit it further, add a terminal velocity as well.
