Output voltage of Crystal Oscillators
The discussion centers around the use of crystal oscillators to generate a 200kHz signal from a 12V, 50Hz input source, particularly in the context of a circuit that interfaces with a strain gauge. Participants explore the functioning of crystal oscillators, their output voltage characteristics, and alternative methods for achieving the desired frequency.
  • One participant describes their circuit requirements, indicating a need for a 200kHz output signal that varies between 3V and 12V based on strain gauge input.
  • Another participant clarifies that a crystal oscillator functions as a high-Q RLC resonator and requires a suitable amplifier to produce an output signal.
  • A question is posed regarding the price range of amplifiers needed for the oscillator and how to determine the output voltage after connection.
  • A detailed explanation is provided about crystal oscillators, emphasizing that the output AC voltage does not directly correspond to the input DC voltage and is influenced by circuit design and load.
  • It is noted that the output voltage can be adjusted using circuit components, and the load may also affect the output based on the strain gauge's force application.
Participants express varying views on the relationship between input and output voltages of crystal oscillators, with some emphasizing that the output voltage is not simply a reflection of the input voltage. There is no consensus on the best approach to achieve the desired output voltage or the necessity of using a crystal oscillator versus alternative methods.
Participants mention the need for a regulated DC supply for the oscillator and the importance of circuit design in determining output characteristics. There are unresolved questions regarding the specific output voltage and the impact of load variations.
Synovial
I am currently building a circuit that produces a 200khz signal with a potential difference of 3 - 12 volts, depending on the force applied to a strain gauge. The input voltage is a 12V, 50hz source. With no force applied to the strain gauge, the output is to be 3V and 12V at breaking force.
From my research I discovered that I can use a crystal oscillator to produce the 200khz signal, except I am having trouble understanding exactly how the component works and its output voltage. Should I convert the input voltage to DC, then run it through the oscillator and the voltage of the input DC will be the voltage of the 200khz signal produced by the oscillator? That is, is the voltage input the same as the output (perhaps a small decrease due to the resistance of the component) across this component?
Thanks in advance.
It's not what you think. It's more like a high-Q RLC resonator. It doesn't do anything unless you connect it to the right kind of amplifier. The whole thing is then a 200KHz oscillator.
What is the standard price range on these amplifiers, and once I connect the oscillator to the aforementioned amplifier, how can I determine the output voltage? Or alternatively, is there an easier way to convert the 50hz signal to a 200khz signal?
A crystal oscillator is a transistor circuit with a dozen or so components, and including a quartz crystal in a hermetic package. Like most electronic circuits, it will require a regulated DC supply. This oscillator will in turn give a constant frequency output, of fixed amplitude. Each crystal is designed for a specific frequency and this cannot* be changed.
You could just as easily construct a 200kHz oscillator using C's and R's around a transistor or op-amp. The crystal oscillator usually has a more accurate frequency, though, this is sometimes important.
I can provide some insight into the functioning of crystal oscillators and their output voltage.
Firstly, a crystal oscillator is an electronic component that uses the mechanical resonance of a piezoelectric crystal to generate a precise frequency signal. The input voltage to the oscillator is typically a DC voltage, and the output is an alternating current (AC) signal with a specific frequency.
In terms of the output voltage, it is important to note that the voltage of the input DC does not necessarily equate to the voltage of the output AC signal. The output voltage of a crystal oscillator is determined by several factors, including the type of crystal used, the circuit design, and the load connected to the oscillator.
In your case, with a 12V, 50Hz input voltage, the output frequency of the oscillator will be 200kHz, but the voltage may vary depending on the load and circuit design. It is possible to use a voltage regulator or other circuit components to adjust the output voltage to meet your desired range of 3-12V.
Additionally, the force applied to the strain gauge may also affect the output voltage of the oscillator, as it can impact the load connected to the oscillator. It is important to consider the overall circuit design and load when determining the output voltage of the crystal oscillator.
In summary, the output voltage of a crystal oscillator is not solely determined by the input voltage, and it is important to consider other factors such as circuit design and load. I would recommend consulting with a professional or conducting further research to ensure the proper functioning and voltage range of your circuit.
  • · Replies 38 ·
  • · Replies 39 ·
  • · Replies 32 ·
