A Tensor Problem: A skew-symmetric tensor and another tensor
  • Thread starter Thread starter kudoushinichi88
    Tensor
The discussion focuses on evaluating the expression (B_{ij} B_{kl} + B_{il}B_{kj})A_{ik} involving a skew-symmetric tensor A_{ij} and a second-order tensor B_{ij}. The key insight is recognizing the structure of the expression, which resembles the interaction of Levi-Civita symbols and Kronecker deltas. The final simplified form of the expression is 2B_{mj} B_{ml} A_{nn}, where the indices are summed according to Einstein notation. This conclusion is reached by manipulating the indices and factoring appropriately.
  • Understanding of tensor algebra and operations
  • Familiarity with skew-symmetric tensors and their properties
  • Knowledge of Einstein summation convention
  • Basic concepts of Levi-Civita symbols and Kronecker delta
  • Study the properties of skew-symmetric tensors in depth
  • Learn about the Levi-Civita symbol and its applications in tensor calculus
  • Explore advanced tensor manipulation techniques
  • Investigate the implications of Einstein summation in tensor expressions
Students and researchers in mathematics and physics, particularly those working with tensor analysis and applications in mechanics or relativity.
kudoushinichi88
If [itex]A_{ij}[/itex] is a skew-symmetric tensor, and [itex]B_{ij}[/itex] is a second-order tensor, evaluate the expression
[tex](B_{ij} B_{kl} + B_{il}B_{kj})A_{ik}[/tex]
and express the final answer in its simplest form.
For a skew-symmetric tensor, [itex]A_{ik}=-A_{ki}[/itex]
I'm stuck and unsure what's the first step. I notice that the expression in the bracket looks similar to what happens when two Levi-Civita symbols come together to form an expression of two pairs of the Kronecker delta. Other than that I'm quite lost. Can I get a tip please?
You are probably summing over all the repeated indices, right? Remember then that the dummy indices are arbitrary, and you can for example swap k and i if you feel like it. Using this, maybe you can write the expression into a form where you take BijBkl as a common factor, multiplying some expression containing the tensor A.
Here's what I have so far:
[tex] (B_{ij} B_{kl} + B_{il}B_{kj})A_{ik}\\<br /> =B_{ij} B_{1l}A_{i1}+B_{ij}B_{2l}A_{i2}+B_{il} B_{1l}A_{i1}+B_{il}B_{2j}A_{i2}\\<br /> =B_{1j} B_{1l}A_{11}+B_{2j} B_{1l}A_{21}+B_{1j}B_{2l}A_{12}+B_{2j}B_{2l}A_{22}+B_{1l} B_{1l}A_{11}+B_{2l} B_{1l}A_{21}+B_{1l}B_{2j}A_{12}+B_{2l}B_{2j}A_{22}\\<br /> =2B_{1j} B_{1l}A_{11}+2B_{2l}B_{2j}A_{22}[/tex]
So the final answer that I can give is... [tex]2\sum_i B_{ij} B_{il} A_{ii}[/tex] or in the Einstein summation, [tex]2B_{mj} B_{ml} A_{nn}[/tex] with nn no sum.
If this is correct, is there any other way to write this without the no sum?
  • · Replies 22 ·
13K
  • · Replies 19 ·
14K
9K
