Quick 2D Motion Question (wind resistance)
The problem involves determining the real velocity of an airplane flying at a specified speed and direction while affected by wind. The subject area pertains to vector addition in two-dimensional motion, specifically in the context of relative velocities.
  • Participants discuss the meaning of "real velocity" and whether it refers to displacement or a different concept. There is mention of using a graphical method to visualize the problem and apply the Pythagorean theorem and trigonometric laws. Questions arise about the correct interpretation of the velocities relative to air and ground.
Participants are actively engaging with the problem, clarifying definitions and relationships between the velocities. Some guidance on using vector addition has been provided, and there is a recognition of the need to correctly represent the vectors in a triangle to find the unknowns. However, no consensus on a specific method has been reached.
Participants are working within the constraints of the problem statement and are questioning the definitions of the velocities involved. There is an emphasis on understanding the relationships between the different velocities rather than solving for a final answer.
Vroc
An airplane is flying 100m/s (N20E) according to the pilot, but is in a wind that is blowing 40 m/s (S10E). What is the plane's real velocity?
Pythagorean Therom
Cosin and Sin Laws
Component Method
Okay, I think I can easily get the answer if I know what this question is asking me. By real velocity, Does it mean the displacement from point 100 m/s (N20E) to 40 m/s (S20E)? Like, I can draw it on a graph and make the triangle. I would then calculate the angle and length of the unknown side. If that's not it, Then how would I go about getting it? Please Help me understand this.
Hi Vroc! :smile:
Vroc said:
An airplane is flying 100m/s (N20E) according to the pilot …
It means the velocity Vpa of the plane relative to the air is 100 m/s (N20E)
you're given Vag, the velocity of the air relative to the ground,
and you need to find Vpg, the velocity of the plane relative to the ground. :wink:
tiny-tim said:
Hi Vroc! :smile:
What? I just need to know what formula to use or how I can use my graph to find the answer.
I'm given the planes Velocity (100m/s n20e) and than the wind (40 m/s s10e)
no, that's not the plane's velocity (relative to the ground), it's the plane's velocity relative to the air
now use vector addition
Okay, If I can use vector addiction, than I can do it the way I mentioned earlier by making a triangle and finding the unknown side and angle because they both are ways of finding the same thing. correct?
correct :smile:
(and make sure your vector triangle has the arrows the right way round,
so that Vpg = Vpa + Vag :wink:)
tiny-tim said:
correct :smile:
Thank you so much.
  • · Replies 39 ·
  • · Replies 20 ·
