What could be causing my rocket to never land on the moon?
  • Thread starter Thread starter Hoofbeat
    Break Code
The discussion revolves around troubleshooting a coding issue related to simulating a rocket's trajectory to land on the moon. Participants are examining the code's logic, particularly focusing on variable initialization and the conditions under which the rocket is deemed to have landed.
  • Homework-related
  • One participant describes their code for simulating a rocket landing and notes that it never seems to land on the moon, despite adjustments to angle increments.
  • Another participant suggests that certain variables, specifically rrx and rry, should be reset for each angle iteration, implying that they may retain values from previous iterations.
  • A participant expresses confusion about variable resetting, indicating a lack of programming knowledge and seeking clarification on how to properly reset variables.
  • Further clarification is provided regarding the scope of variables in loops, emphasizing that only variables defined inside the loop are reset.
  • After resetting the values for each iteration, the original problem persists, prompting a request for additional suggestions.
  • Another participant proposes initializing the rocket's coordinates (xr and yr) instead of the previously mentioned variables, which leads to a positive outcome for the original poster.
Participants do not reach a consensus on the initial cause of the issue, but there is agreement on the importance of resetting variables. The discussion includes multiple suggestions and approaches without a definitive resolution until the final suggestion appears to resolve the issue for the original poster.
There are limitations regarding the understanding of variable scope in programming, and the discussion reflects varying levels of programming knowledge among participants.
This discussion may be useful for individuals working on programming assignments related to physics simulations, particularly those interested in trajectory calculations and variable management in coding.
Hoofbeat
Heya, could someone take a look at my code for me? I'm trying to do the second part of "Part 1" from the problem sheet:
http://www.hoofbeat.tv/Page4%20Scan.jpg [apologies the image is small on the site - I don't have enough webspace to upload it any larger]
However, my code never seems to break, ie. the rocket never lands on the moon. So I tried using the conditions from the first part of section 1 and seeing if I could get the correct angle of 89.9degrees. This works if I consider angles in the range 89.8->90.0 incrementing in 0.1 and it prints out "the rocket has landed on the moon". However, as soon as I set the range any bigger the process just continues until it has covered the range of angles and thus the rocket supposedly never lands on the moon.
One again the demonstrator couldn't find out what I was doing wrong (he suggested I changed my floats to doubles, but it hasn't made any difference). If someone, could offer any hints/suggestions I'd be really greatful as I really need to get this section finished so I can move on to part 2 (which looks horrible as well).
Thanks once again. My code is below:
Code:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
/*CO51 ROCKET SCIENCE - Part 1 ii)*/
/*A program designed to plot the trajectory of a rocket on a mission to land on the moon*/
int main(int argc, char *argv[])
  FILE  *fout;
  fout = fopen("rocket2.data", "w");
  if (fout == NULL)
    printf("Cannot open rocket2.data\n");
    exit(-1);
  //const double pi=3.1415; /*This defines the value of pi*/
  const double u=0.0066; /*This defines the intial velocity of rocket and is equivalent to v*/
  const double xe=0, ye=0; /*These are the Earth's coords: (0, 0) - ie. where it's centre lies*/
  const double xm=0, ym=225.7; /*These are the Moon's coords: (0, 225.7)*/
  const double Mm=1.0, Me=83.3; /*These are the masses of the Moon & Earth Respectively*/
  const double Rm=1.0, Re=3.7; /*These are the radii of the Moon & Earth Respectively*/
  const double G=9.63e-7; /*This is the gravitational field constant*/
  int dt=10; /*This is the step size delta.t*/
  double xr=0.0, yr=3.7; /*These are the coords of the Rocket)*/
  double vx, vy; /*These are the current velocities in both x & y directions*/
  double ax=0, ay=0; /*These are the accelerations in both x & y directions*/
  double rrx, rry; /*These are the components of the vector from Earth to Rocket*/
  double rmx, rmy; /*These are the components of the vector from Earth to Moon*/
                         /*Do NOT confuse with Re & Rm which are radii*/
  double de=0.0, dm=0.0; /*These are abbreviations for calculations late on to improve layout*/
  double theta=0.0, angle=0.0; /*'Theta' is in degrees; 'angle' is in radians*/
  double landed=0;
  int t=0;
  /*Using a for loop*/
 for (theta=89.8; theta<=90.0; theta=theta+0.1)
    angle=((theta*M_PI)/180.0);
    for (t=0;t<=1000000;t=t+dt) /*The rocket may not reach the moon, so we consider a*/
                                /*time period of 1000000 and see where it is at this point*/
        vx = u*cos(angle);
        vy = u*sin(angle);
        rmx = xm - xe;
        rmy = ym - ye;
        rrx = xr - xe;
        rry = yr - ye;
        de = sqrt(rrx*rrx+rry*rry);
        dm = sqrt((rrx-rmx)*(rrx-rmx) + (rry-rmy)*(rry-rmy));
        ax=
        (G*Me/(de*de))*(-rrx)/de +
        (G*Mm/(dm*dm))*(rmx-rrx)/dm;
        ay=
        G*Me/(de*de)*(-rry)/de +
        G*Mm/(dm*dm)*(rmy-rry)/dm;
        vx=vx+(dt*ax); /*Step 4 of Euler's method*/
        vy=vy+(dt*ay); /*Step 4 of Euler's method*/
        xr=xr+(dt*vx); /*Step 5 of Euler's method*/
        yr=yr+(dt*vy); /*Step 5 of Euler's method*/
        //printf("X coord: %lf\n", xr);
        //printf("Y coord: %lf\n", yr);
        //printf("distance to moon: %lf\n", dm);
        if(dm < Rm) {
            landed=1; /*ie. the Rocket has landed on the moon*/
            break;
    printf("Angle in degrees: %f\n", theta);
    printf("Distance to moon after max time: %f\n", dm);
    if(landed==1) {
       printf("The rocket has hit the moon\n");
       printf("Angle Required: %f\n", angle);
       //printf("Distance to moon after max time: %lf\n", dm);
       break;
       fprintf(fout, "%lf\t%lf\n", xr, yr);
  system("PAUSE");	/*This code is specific to a Windows system  and*/
  return 0;               /*prevents the window closing automatically*/
Computer science news on Phys.org
Have you considered that there are variables, say rrx and rry, other than t that should be reset on every shot?
Ummm interesting comment. I assumed that for each angle iteration the whole process would start again and all values would automatically start at their initial assigned values. Is that not the case then and how do I go about resetting them? (you can tell I don't know how to program!)
Well, only the stuff inside the braces gets re-executed:
Code:
//Stuff out here is not repeated
int i=0;
int j=0;
printf ("This is going to be printed once.\n");
//Stuff inside the loop gets repeated
for(i=0;i<5;i++) {
   printf ("This gets printed five times.\n");
   for(j=0;j<4;j++) {
      printf("This gets printed 20 times\n");
You can just set them in the exterior loop - something like:
Code:
for(angle=0;angle<2*M_pi;angle=angle+.001) {
   vx=u*cos(angle);
   vy=u*sin(angle);
   rrx=0;
   rry=0
   for(t=0;t<100000;t+=10) {
Soz...I'm back again. I just reset the values for each iteration, but the problem still exists :(
Any other ideas?
Any other ideas?
Can you try setting
xr=0
yr=3.7
instead of rrx and rry?
NateTG said:
Can you try setting
xr=0
yr=3.7
YAY! That seems to work fine. Thanks ever so much :-p :smile:
